76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
In my rush to discover the clunk noise coming from the front end 5days before Rt66, I got sloppy. I sat the outer wheel bearings upon a piece of dirty cardboard vs. a clean baggie, when dropping the struts. The one damn time I break the rule it bites me in the butt. (IMG:style_emoticons/default/headbang.gif)
I originally thought the noise was the tire separating, which would have been Ron's fault for making me exceed my tires speed rating on our way to Rt66. (IMG:style_emoticons/default/shades.gif) When we returned I put it on the lift and when spun the L wheel had a rough spot. Pulled it apart and sure enough the outer bearing is toast. Bearings only had 7K on them. Damn it! And I did both sides the same so look out R side. Time to do both sides; again. Laziness shows no mercy. (IMG:style_emoticons/default/bootyshake.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
The correct answer would be NO. 'Perfect balance on the corners'. All bases covered.
Lo-Fi Version | Time is now: 26th June 2024 - 04:11 AM |
