Turn Signal Switch ... Need help with Mark's WCR car |
cary |
May 15 2016, 12:05 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Good Morning,
I've been laying low after I had isssues with tracing down the electronic issues with the tach in the blue car. The tach was dead. I replaced it with a working silver dot. The only issue seemed to be the size of the bulb holders. Swapped them out, everything seems ok. Am I missing any hidden issues? But I'm having trouble with the turn signal switch. Turning on the left signal blows fuse number #9. I hope Mike Bellis is around today, he seems to have a good grasp on switch issues. Here's where we're at: * Stalk switch for the parking brake lights work with key off. Both sides, all lamps. (IMG:style_emoticons/default/biggrin.gif) * Light switch turns on the all parking lamps, key off. (IMG:style_emoticons/default/biggrin.gif) * Emergency flasher works key off and on with the turn signal harness unplugged from the column switch, all lamps (IMG:style_emoticons/default/biggrin.gif) * Turn signal in the down position works. Both front and back. Seems backwards. turns on the right rather than the left. I switched places on the black/white and the black/green in the harness connector at the switch. Changing them did nothing. I'll deal with that later. * Up postion blows the fuse #9. After going thru a pile of fuses I went to NAPA and bought a couple circuit breakers for $8 each. * Next step was to try the switch from my 73. Doesn't fit but everything works. (IMG:style_emoticons/default/biggrin.gif) * Then I proceed to test out the 75 switch as per Mike's numerous posts. Everything tests out other than continuity between blk/wh/grn and black/green. Zero, nothing. So the $1,000, 000 question. Do I swap out the 73 wiper switch and stack it on the 75 washer. Will that work ? Will It fit ? Or tear into the only 75 wiper switch I have? EDITED @ 6:50 PM Here's the info I started with this AM. http://www.914world.com/bbs2/index.php?sho...112819&st=0 |
Jeffs9146 |
May 15 2016, 03:46 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
When we did Lennies914 car the #9 fuse was blowing just like yours. It turned out that the harness where it goes through from the engine compartment into the trunk to the left blinker was pinched. One of the wires grounded against the chassis. We taped it up and all was good.
Just a shot in the dark!! |
Lo-Fi Version | Time is now: 18th January 2025 - 11:18 PM |
