> Turn Signal Switch ... Need help with Mark's WCR car
cary
post May 15 2016, 12:05 PM
Good Morning,
I've been laying low after I had isssues with tracing down the electronic issues with the tach in the blue car. The tach was dead. I replaced it with a working silver dot. The only issue seemed to be the size of the bulb holders. Swapped them out, everything seems ok. Am I missing any hidden issues?
But I'm having trouble with the turn signal switch. Turning on the left signal blows fuse number #9. I hope Mike Bellis is around today, he seems to have a good grasp on switch issues.
Here's where we're at:
* Stalk switch for the parking brake lights work with key off. Both sides, all lamps. (IMG:style_emoticons/default/biggrin.gif)
* Light switch turns on the all parking lamps, key off. (IMG:style_emoticons/default/biggrin.gif)
* Emergency flasher works key off and on with the turn signal harness unplugged from the column switch, all lamps (IMG:style_emoticons/default/biggrin.gif)
* Turn signal in the down position works. Both front and back. Seems backwards. turns on the right rather than the left. I switched places on the black/white and the black/green in the harness connector at the switch. Changing them did nothing. I'll deal with that later.
* Up postion blows the fuse #9. After going thru a pile of fuses I went to NAPA and bought a couple circuit breakers for $8 each.
* Next step was to try the switch from my 73. Doesn't fit but everything works. (IMG:style_emoticons/default/biggrin.gif)
* Then I proceed to test out the 75 switch as per Mike's numerous posts. Everything tests out other than continuity between blk/wh/grn and black/green. Zero, nothing.
So the $1,000, 000 question. Do I swap out the 73 wiper switch and stack it on the 75 washer. Will that work ? Will It fit ?
Or tear into the only 75 wiper switch I have?
EDITED @ 6:50 PM
Here's the info I started with this AM.
http://www.914world.com/bbs2/index.php?sho...112819&st=0
cary
post May 15 2016, 08:08 PM
Here's what the top of the 75 turn signal switch looks like.
At the end of the day only a couple issues. 1. Turn signal doesn't cancel. Not great, but can be dealt with. 2. The instrument illumination lights come on when the right side is in key off Euro parking light mode. It can be dealt with later.
Now the new question. Has anyone opened up the lower layer of a wiper switch to clean it and been able to put it back together?
I opened up one of my old broken ones to see what the issue was.
The yellow line is turn signal.
The red line is the Euro parking lights.
Don't really understand how one side would work and not the other.
Here's what it looks like under the hood/tin plate.
cary
post May 16 2016, 11:33 PM
QUOTE(cary @ May 15 2016, 07:08 PM) *
I found the issue. One of the PO's had tied the wires at the headlight switch from the right parking lamp terminal (58R) (current track 31) to the instrument illumination wires on terminal 58A. (current track 36) We're talking a splice type union.
https://www.zoro.com/3m-displacement-connec...mp;gclsrc=aw.ds
This created a monster size direct short in the wiper switch. Which melted the switch, rather than blowing a fuse.
rick 918-S
post May 17 2016, 05:59 PM
Hey nice rack! -Celette
QUOTE(cary @ May 17 2016, 12:33 AM) *
Some guys should never be allowed to own a wire cutter and electrical tape (IMG:style_emoticons/default/slap.gif)
cary
post May 17 2016, 10:20 PM
QUOTE(rick 918-S @ May 17 2016, 04:59 PM) *
Rick this is what caused all the carnage. Tied two different circuits together. Which circumvented the fuses. Which melted two turn signal switches, some wiring and an ignition switch.
The taped spots are where they were tied together. They'll get heat shrinked in the am when I get every thing dressing out and tucked back up.
cary   Turn Signal Switch ... Need help with Mark's WCR car   May 15 2016, 12:05 PM
cary   Nothing from the Brain Trust ................. ???...   May 15 2016, 01:12 PM
rhodyguy   Can you hear the relay clicking when you toggle th...   May 15 2016, 01:41 PM
cary   Can you hear the relay clicking when you toggle t...   May 15 2016, 02:24 PM
914Sixer   75-76 wiper switch is unique. It was sourced from...   May 15 2016, 01:41 PM
cary   75-76 wiper switch is unique. It was sourced fro...   May 15 2016, 02:25 PM
Mike Bellis   Unfortunately I swapped out my column for a tilt a...   May 15 2016, 02:47 PM
cary   Devine intervention. Came back from lunch and the ...   May 15 2016, 03:30 PM
Jeffs9146   When we did Lennies914 car the #9 fuse was blowing...   May 15 2016, 03:46 PM
Mikey914   Found a potential spare. Untested, I'll get to...   May 15 2016, 07:38 PM
cary   I've got the testing part down ............ LO...   May 15 2016, 07:52 PM
cary   Here's what the top of the 75 turn signal swit...   May 15 2016, 08:08 PM
cary   2. The instrument illumination lights come on wh...   May 16 2016, 11:33 PM
rick 918-S   2. The instrument illumination lights come on w...   May 17 2016, 05:59 PM
cary   Some guys should never be allowed to own a wire ...   May 17 2016, 10:20 PM
cary   Oh yeah, short episode of Tool Whore ................   May 15 2016, 08:12 PM
r_towle   Oh yeah, short episode of Tool Whore ...............   May 17 2016, 07:34 PM
cary   Ok, whore... Where did you get the circuit break...   May 17 2016, 10:02 PM
cary   Mark will be adding them to the catalog at 914Rubb...   May 15 2016, 08:44 PM
Mikey914   Again, Thanks Cary, I would not have the time to t...   May 17 2016, 12:26 PM
Wyvern   The circuit breaker is a GREAT idea. Check out the...   May 17 2016, 10:24 PM
cary   Finally beat this critter a little after lunch. Co...   May 17 2016, 10:43 PM
cary   Here's where I start in the am. Wrap everythin...   May 17 2016, 10:57 PM
- Lo-Fi Version Time is now: 18th January 2025 - 10:54 PM
