Any idea how to solve bad door clearence, longitudinal repared without stiffening |
914Gelb |
May 18 2016, 04:55 AM
Member Group: Members Posts: 103 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result. My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand. The question is how can I fix this and if you had the same topic how was it fixed by you. Attached thumbnail(s) |
914Gelb |
May 18 2016, 04:59 AM
one more
tomrev |
May 18 2016, 06:14 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
I think you will need to cut out the past patching, so the tub can be straightened out, and then do a proper re-weld, without warping the car. Pretty sure it was on jack stands when welded, and and the heat pulled it out of whack. I'm sure you know all this. A Six will be worth the effort!
Lo-Fi Version | Time is now: 7th January 2025 - 02:51 AM |
