> Any idea how to solve bad door clearence, longitudinal repared without stiffening
914Gelb
post May 18 2016, 04:55 AM
Region Association: Austria
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result.
My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand.
The question is how can I fix this and if you had the same topic how was it fixed by you.
dlee6204
post May 18 2016, 06:19 AM
Howdy
Unfortunately the only way to properly fix it is to cut out and replace the entire long. The previous work done is pretty bad.
914Gelb   Any idea how to solve bad door clearence   May 18 2016, 04:55 AM
914Gelb   More pictures   May 18 2016, 04:58 AM
914Gelb   one more   May 18 2016, 04:59 AM
tomrev   I think you will need to cut out the past patching...   May 18 2016, 06:14 AM
dlee6204   Unfortunately the only way to properly fix it is t...   May 18 2016, 06:19 AM
rgalla9146   It might not be as bad as you think. I'd ...   May 18 2016, 08:21 AM
914Gelb   To roll the car and check the clearance is somethi...   May 18 2016, 10:24 AM
mbseto   My longs look a lot like that. Previous owner wel...   May 18 2016, 02:13 PM
Cairo94507   If you feel the previous repairs were done poorly,...   May 18 2016, 03:33 PM
OU812   Allais, another sunflower yellow car covered in Re...   May 18 2016, 06:31 PM
cary   Is a 914-6 conversion or the real deal? Makes a bi...   May 18 2016, 08:08 PM
rick 918-S   Start by studying these dimensions. http://www.91...   May 18 2016, 09:01 PM
914Gelb   Hello Cary, The car is a real 914-6, I never would...   May 18 2016, 11:44 PM
914Gelb   and more pictures   May 18 2016, 11:47 PM
914Gelb   my hand made cellete   May 18 2016, 11:53 PM
914Gelb   front trunk   May 18 2016, 11:57 PM
cary   Nice, good luck on your project. Your in good han...   May 19 2016, 12:01 AM
914Gelb   rear trunk   May 19 2016, 12:03 AM
914Gelb   right outer side   May 19 2016, 12:06 AM
914Gelb   again right side   May 19 2016, 12:07 AM
914Gelb   engine   May 19 2016, 12:16 AM
914Gelb   transmission, rebuild by my own, bought tools to a...   May 19 2016, 12:20 AM
914Gelb   pinion   May 19 2016, 12:26 AM
914Gelb   Before the rebuild, I'm sitting in the 914-6   May 19 2016, 12:36 AM
sixnotfour   looks like a pretty decent six, other than needing...   May 19 2016, 05:54 AM
Luke M   looks like a pretty decent six, other than needin...   May 19 2016, 04:41 PM
914Gelb   [quote name='sixnotfour' post='2347054' date='May...   May 20 2016, 12:13 AM
914Gelb   Yes it was yellow, and after restoration it will b...   May 19 2016, 06:19 AM
rick 918-S   After viewing the photos that car is not bad just ...   May 19 2016, 06:48 AM
Cairo94507   Yeah, that Six does not look bad at all. But unti...   May 19 2016, 07:01 AM
914Gelb   For the undercoating and Paint removal I decided t...   May 19 2016, 08:56 AM
worn   Nice tool but it is still a dirty long process....   May 24 2016, 10:22 AM
914Gelb   Nice tool but it is still a dirty long process...   May 25 2016, 02:53 AM
SixerJ   Another cool 914-6 thread. Subscribed and looking ...   May 19 2016, 12:44 PM
sixnotfour   I know , But in the Long run it will be worth it...   May 19 2016, 02:15 PM
rick 918-S   Wow! Those parts are Awesome!   May 20 2016, 07:01 AM
cary   I'm on my phone at WCR? Is that product from M...   May 20 2016, 08:10 AM
sixnotfour   I'm on my phone at WCR? Is that product from ...   May 20 2016, 10:07 AM
jd74914   For the undercoating and Paint removal I decided ...   May 20 2016, 08:18 AM
rick 918-S   We need Pete to get a shipment from Mittlemotor so...   May 20 2016, 08:45 AM
sixnotfour   We need Pete to get a shipment from Mittlemotor s...   May 20 2016, 09:49 AM
914Gelb   We need Pete to get a shipment from Mittlemotor s...   May 20 2016, 09:53 AM
sixnotfour   We need Pete to get a shipment from Mittlemotor ...   May 20 2016, 10:10 AM
cary   Another $$$ factor to consider is f...   May 20 2016, 10:10 AM
914Gelb   Another $$$ factor to consider is ...   May 20 2016, 10:20 AM
Luke M   Another $$$ factor to consider is...   May 21 2016, 05:37 AM
SixerJ   Patrik at http://www.914er-teile.de carries those ...   May 20 2016, 11:49 AM
Luke M   Ok, so I've called Mittlemotors and all I get ...   May 24 2016, 07:55 AM
914Gelb   Ok, so I've called Mittlemotors and all I get...   May 25 2016, 02:21 AM
Luke M   [quote name='Luke M' post='2349656' date='May 24 ...   May 25 2016, 06:46 AM
914Gelb   After many months I can continue working on my 914...   Jun 21 2017, 04:42 AM
914Gelb   RE: Any idea how to solve bad door clearence   Jun 21 2017, 04:45 AM
914Gelb   Started removing rubber   Jun 21 2017, 04:48 AM
914Gelb   Here I found a small kink in the metal, 1st I was ...   Jun 21 2017, 04:59 AM
Cairo94507   I am glad to see this project moving along. :bee...   Jun 21 2017, 06:10 AM
Luke M   Keep up the work and post lots of pics of the repa...   Jun 21 2017, 06:36 AM
914Gelb   no this is not the demage I mean see the picture I...   Jun 21 2017, 06:49 AM
bretth   Maybe a previous owner was trying to improve tire ...   Jun 21 2017, 07:46 AM
cary   Do you have some door braces ?   Jun 21 2017, 08:17 AM
914Gelb   Door braces are not installed, bevore I start well...   Jun 21 2017, 11:14 PM
flyer86d   Looks like a nice car. You know, all of those prev...   Jun 22 2017, 05:47 AM
914Gelb   Looks like a nice car. You know, all of those pre...   Jun 22 2017, 06:08 AM
914Gelb   I continued working on my 914-6. The next step was...   Sep 19 2017, 11:28 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:29 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:30 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:31 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:33 PM
914Gelb   :cheer: It looks like the body of my car is now r...   Sep 27 2023, 07:03 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:05 AM
mepstein   :trophy:   Sep 27 2023, 07:06 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:06 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:07 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:09 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:11 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:14 AM
burton73   You are doing a super job on your 6 but I woul...   Sep 27 2023, 03:52 PM
rhodyguy   WOW!   Sep 27 2023, 07:18 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:19 AM
mlindner   Wow, that is a great job. will be fun to see it al...   Sep 27 2023, 07:24 AM
914Gelb   All the pain job you see I made by my own, covers ...   Sep 27 2023, 07:29 AM
Cairo94507   Very nice work indeed; congratulations on getting ...   Sep 27 2023, 08:43 AM
porschetub   Wow nice work ,it is a real milestone to have in p...   Sep 28 2023, 01:15 PM
930cabman   Great save, many guys would have bailed, you must ...   Sep 28 2023, 01:50 PM
914Gelb   Slowly I proceed with the rebuild of my car, there...   Sep 24 2024, 11:29 PM
914Gelb   The paint is single stage from glasuit, look at...   Sep 24 2024, 11:32 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:34 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:35 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:37 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:38 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:40 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:41 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:43 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:45 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:46 PM
rick 918-S   Very nice result. Your persistence paid off. :firs...   Sep 25 2024, 05:59 AM
930cabman   Very nice result. Your persistence paid off. :fir...   Sep 25 2024, 02:08 PM
Cairo94507   :popcorn: :beer2:   Sep 25 2024, 07:49 AM
Root_Werks   Wow, this project has come a long way! Lookin...   Sep 25 2024, 03:54 PM
84 User(s) are reading this topic (84 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 03:07 AM
