> Any idea how to solve bad door clearence, longitudinal repared without stiffening
914Gelb
post May 18 2016, 04:55 AM
Region Association: Austria
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result.
My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand.
The question is how can I fix this and if you had the same topic how was it fixed by you.
SixerJ
post May 20 2016, 11:49 AM
Region Association: England
Patrik at http://www.914er-teile.de carries those as well. Nice guy to dra with & I bought my new -6 OEM tank off him
Expensive but nice and what I will be using on my car if or rather when I need them
Keep up the good work
914Gelb   Any idea how to solve bad door clearence   May 18 2016, 04:55 AM
914Gelb   More pictures   May 18 2016, 04:58 AM
914Gelb   one more   May 18 2016, 04:59 AM
tomrev   I think you will need to cut out the past patching...   May 18 2016, 06:14 AM
dlee6204   Unfortunately the only way to properly fix it is t...   May 18 2016, 06:19 AM
rgalla9146   It might not be as bad as you think. I'd ...   May 18 2016, 08:21 AM
914Gelb   To roll the car and check the clearance is somethi...   May 18 2016, 10:24 AM
mbseto   My longs look a lot like that. Previous owner wel...   May 18 2016, 02:13 PM
Cairo94507   If you feel the previous repairs were done poorly,...   May 18 2016, 03:33 PM
OU812   Allais, another sunflower yellow car covered in Re...   May 18 2016, 06:31 PM
cary   Is a 914-6 conversion or the real deal? Makes a bi...   May 18 2016, 08:08 PM
rick 918-S   Start by studying these dimensions. http://www.91...   May 18 2016, 09:01 PM
914Gelb   Hello Cary, The car is a real 914-6, I never would...   May 18 2016, 11:44 PM
914Gelb   and more pictures   May 18 2016, 11:47 PM
914Gelb   my hand made cellete   May 18 2016, 11:53 PM
914Gelb   front trunk   May 18 2016, 11:57 PM
cary   Nice, good luck on your project. Your in good han...   May 19 2016, 12:01 AM
914Gelb   rear trunk   May 19 2016, 12:03 AM
914Gelb   right outer side   May 19 2016, 12:06 AM
914Gelb   again right side   May 19 2016, 12:07 AM
914Gelb   engine   May 19 2016, 12:16 AM
914Gelb   transmission, rebuild by my own, bought tools to a...   May 19 2016, 12:20 AM
914Gelb   pinion   May 19 2016, 12:26 AM
914Gelb   Before the rebuild, I'm sitting in the 914-6   May 19 2016, 12:36 AM
sixnotfour   looks like a pretty decent six, other than needing...   May 19 2016, 05:54 AM
Luke M   looks like a pretty decent six, other than needin...   May 19 2016, 04:41 PM
914Gelb   [quote name='sixnotfour' post='2347054' date='May...   May 20 2016, 12:13 AM
914Gelb   Yes it was yellow, and after restoration it will b...   May 19 2016, 06:19 AM
rick 918-S   After viewing the photos that car is not bad just ...   May 19 2016, 06:48 AM
Cairo94507   Yeah, that Six does not look bad at all. But unti...   May 19 2016, 07:01 AM
914Gelb   For the undercoating and Paint removal I decided t...   May 19 2016, 08:56 AM
worn   Nice tool but it is still a dirty long process....   May 24 2016, 10:22 AM
914Gelb   Nice tool but it is still a dirty long process...   May 25 2016, 02:53 AM
SixerJ   Another cool 914-6 thread. Subscribed and looking ...   May 19 2016, 12:44 PM
sixnotfour   I know , But in the Long run it will be worth it...   May 19 2016, 02:15 PM
rick 918-S   Wow! Those parts are Awesome!   May 20 2016, 07:01 AM
cary   I'm on my phone at WCR? Is that product from M...   May 20 2016, 08:10 AM
sixnotfour   I'm on my phone at WCR? Is that product from ...   May 20 2016, 10:07 AM
jd74914   For the undercoating and Paint removal I decided ...   May 20 2016, 08:18 AM
rick 918-S   We need Pete to get a shipment from Mittlemotor so...   May 20 2016, 08:45 AM
sixnotfour   We need Pete to get a shipment from Mittlemotor s...   May 20 2016, 09:49 AM
914Gelb   We need Pete to get a shipment from Mittlemotor s...   May 20 2016, 09:53 AM
sixnotfour   We need Pete to get a shipment from Mittlemotor ...   May 20 2016, 10:10 AM
cary   Another $$$ factor to consider is f...   May 20 2016, 10:10 AM
914Gelb   Another $$$ factor to consider is ...   May 20 2016, 10:20 AM
Luke M   Another $$$ factor to consider is...   May 21 2016, 05:37 AM
SixerJ   Patrik at http://www.914er-teile.de carries those ...   May 20 2016, 11:49 AM
Luke M   Ok, so I've called Mittlemotors and all I get ...   May 24 2016, 07:55 AM
914Gelb   Ok, so I've called Mittlemotors and all I get...   May 25 2016, 02:21 AM
Luke M   [quote name='Luke M' post='2349656' date='May 24 ...   May 25 2016, 06:46 AM
914Gelb   After many months I can continue working on my 914...   Jun 21 2017, 04:42 AM
914Gelb   RE: Any idea how to solve bad door clearence   Jun 21 2017, 04:45 AM
914Gelb   Started removing rubber   Jun 21 2017, 04:48 AM
914Gelb   Here I found a small kink in the metal, 1st I was ...   Jun 21 2017, 04:59 AM
Cairo94507   I am glad to see this project moving along. :bee...   Jun 21 2017, 06:10 AM
Luke M   Keep up the work and post lots of pics of the repa...   Jun 21 2017, 06:36 AM
914Gelb   no this is not the demage I mean see the picture I...   Jun 21 2017, 06:49 AM
bretth   Maybe a previous owner was trying to improve tire ...   Jun 21 2017, 07:46 AM
cary   Do you have some door braces ?   Jun 21 2017, 08:17 AM
914Gelb   Door braces are not installed, bevore I start well...   Jun 21 2017, 11:14 PM
flyer86d   Looks like a nice car. You know, all of those prev...   Jun 22 2017, 05:47 AM
914Gelb   Looks like a nice car. You know, all of those pre...   Jun 22 2017, 06:08 AM
914Gelb   I continued working on my 914-6. The next step was...   Sep 19 2017, 11:28 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:29 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:30 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:31 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 19 2017, 11:33 PM
914Gelb   :cheer: It looks like the body of my car is now r...   Sep 27 2023, 07:03 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:05 AM
mepstein   :trophy:   Sep 27 2023, 07:06 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:06 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:07 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:09 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:11 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:14 AM
burton73   You are doing a super job on your 6 but I woul...   Sep 27 2023, 03:52 PM
rhodyguy   WOW!   Sep 27 2023, 07:18 AM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 27 2023, 07:19 AM
mlindner   Wow, that is a great job. will be fun to see it al...   Sep 27 2023, 07:24 AM
914Gelb   All the pain job you see I made by my own, covers ...   Sep 27 2023, 07:29 AM
Cairo94507   Very nice work indeed; congratulations on getting ...   Sep 27 2023, 08:43 AM
porschetub   Wow nice work ,it is a real milestone to have in p...   Sep 28 2023, 01:15 PM
930cabman   Great save, many guys would have bailed, you must ...   Sep 28 2023, 01:50 PM
914Gelb   Slowly I proceed with the rebuild of my car, there...   Sep 24 2024, 11:29 PM
914Gelb   The paint is single stage from glasuit, look at...   Sep 24 2024, 11:32 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:34 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:35 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:37 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:38 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:40 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:41 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:43 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:45 PM
914Gelb   RE: Any idea how to solve bad door clearence   Sep 24 2024, 11:46 PM
rick 918-S   Very nice result. Your persistence paid off. :firs...   Sep 25 2024, 05:59 AM
930cabman   Very nice result. Your persistence paid off. :fir...   Sep 25 2024, 02:08 PM
Cairo94507   :popcorn: :beer2:   Sep 25 2024, 07:49 AM
Root_Werks   Wow, this project has come a long way! Lookin...   Sep 25 2024, 03:54 PM
76 User(s) are reading this topic (76 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 03:03 AM
