FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
Rotary'14 |
Aug 18 2010, 11:24 PM
I put together an install video,,,
http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. |
malcolm2 |
May 10 2016, 04:45 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? |
Rotary'14 |
May 17 2016, 04:05 PM
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! |
ndfrigi |
May 17 2016, 04:19 PM
Advanced Member Group: Members Posts: 2,959 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! Hi Robert, you tube video still not working. |
Rotary'14 |
May 24 2016, 04:12 PM
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! Hi Robert, you tube video still not working. Thanks Noel,,,, OK,,, I am sure the video works now,,,, cool music is gone and slow soothing music is now in it's place. At least the video is watch-able again. |
Lo-Fi Version | Time is now: 26th November 2024 - 11:19 AM |
