sdoolin |
Member ![]() ![]() Group: Members Posts: 367 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
Yep, I am building a 2056. Have ordered very nearly a complete 2056 engine kit from Type IV Store (LN Engineering). Some questions (I have searched and read MANY threads)...
I have a "spare" 1976 VW Bus short block (no cyl. heads). Assume this will work for a starting point? Issues with oil dipstick? The bus was an automatic so I assume once I remove the "flex plate" that the flywheel from by 914 engine (in car) will bolt up to the crank without issues? Any issues with engine carrier? The bus used a "moustache bar" for mounting to the frame and I am hoping that the cases from the bus/914 are the same for engine mounting? Will re-use existing Crank/rods New crank/rod bearings Will re-use existing cylinders (overbored) KB 96 mm flat topped pistons with Hastings rings Webcam cam (9130 kit from Type IV Store) Type IV Store pushrods, pushrod ends, parkerized lifters, rocker shafts Type IV Store cam bearings Re-use rockers from bus engine? Not sure about this... HAM (Len Hoffman) RS+ spec cylinder heads New Oil pump from Type IV Store New clutch & pressure plate. Re-use flywheel from 914 engine (in the car) Dellorto Dual 40mm carbs, CB Perf manifolds & linkage SSI heat exchangers & Bursch exhaust New fuel pump - will run return lines (have CFR SS Lines in car now and will re-use) Not sure what dizzy to run? I believe I need to check/verify deck height and valve clearance (I know how, just not positive this is required for a 2056 build). I have read a few threads about "setting" compression ration, but do not understand it yet? Anyone have a compression ratio for dummies guide? Anything else I'm missing? Progress so far... ![]() |
sdoolin |
And finally on side goes together (sort of still). I mangled one of the oil scraper rails so need to make an order before I do the other side. For now this is loosely bolted up with spacers and I will return to it when I get back from a week's worth of travel for work.
I still hate the spiral-in wrist pin retainers. No one can change my mind on that. ![]() ![]() Have I mentioned that I hate the new spiral-in wrist pin retainers? |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Have I mentioned that I hate the new spiral-in wrist pin retainers? I saw a youtube vid where the person stretched the springs out so they looked more like a spring than a washer when sitting on the table. Then they can go in with one finger. You just start one end then compress the spring and they snap right in. For getting them out, I took a tiny screwdriver and bent the tip to form a tiny hook to grab the end. Like this one: https://www.youtube.com/watch?v=vOYH_WICGYM |
Lo-Fi Version | Time is now: 28th June 2024 - 03:20 PM |
