bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,560 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
EDIT:
So I picked up about 1000 lbs of parts. Really, cause like I needed them. All three sets of front hubs are spoken for. Getting the first set of rears cleaned up and will install bolts. Here is what I learned so far about the hubs. The rear hubs are drilled and tapped to take bolts that thread in from the back side. Fronts also use thread in hex head bolts that have had the heads ground round to fit flush with the hub. The fronts take 911 "innie" type grease caps that are not included which are available through Pelican at $50.50 each. There are several sets of mono block caliper adapters to adapt bigger brakes to front 3" or 3.5" bolt spacing and rear 914 and 911 trailing arms. I will get the rusted parts cleaned up. Hard to tell from the pics but there are sets of rear caliper spacers for converting rear calipers to use vented rotors. Mono block adapters to add big brakes to 914 or 911 struts. 3 sets of front five lug billet hubs, 5 -1/2 sets of redrilled rear 5 lug hubs. Some of you may recall the CNC machined hubs first offered by Brad Roberts. The person who did them has offered his remaining stock to me to sell off. Seems that Brad left him holding the bag after promising to buy several sets. No big surprise there. These would bolt up to a 914 strut directly with no modifications. It is a package deal and I have to take them with a lot of other 5 lug conversion parts like redrilled rear hubs with allen bolts installed from the back side, redrilled 914 rotors to match. Also are available are the rear caliper spacers to allow use of vented rotors. I will have to figure reasonable pricing. I should have pictures later today. Attached image(s) ![]() ![]() ![]() ![]() ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Interesting. Story I heard was machinist made extras and was selling them on the side, but there are always 2 sides of every story, I can believe the machinist story as well. So confusing (IMG:style_emoticons/default/smile.gif)
There is a small market for sure, since coming back to 914World I've had at least 3 people contact me to see if I can have more made or release the drawing to someone that could make them again (I did the original drawings and worked with the original machine shop, I got one pair of hubs for my part- the 4 lug version) Any 4 lug versions available? I know a few people are still interested in those based on a few PM's. |
Mueller |
Interesting. Story I heard was machinist made extras and was selling them on the side, but there are always 2 sides of every story, I can believe the machinist story as well and does make more sense now knowing more about other peoples dealings with /B So confusing (IMG:style_emoticons/default/smile.gif) There is a small market for sure, since coming back to 914World I've had at least 3 people contact me to see if I can have more made or release the drawing to someone that could make them again (I did the original drawings and worked with the original machine shop, I got one pair of hubs for my part- the 4 lug version) Any 4 lug versions available? I know a few people are still interested in those based on a few PM's. Confirm the years they fit, I "think" the struts are different between the 70/71 and the rest of the later struts? |
Lo-Fi Version | Time is now: 29th June 2024 - 12:48 AM |
