New GB door cards early and late LIKE OEM!, These will be $169 a set of 2 - Will go up after GB |
Mikey914 |
Nov 20 2015, 07:28 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes we will still be doing the fiberglass door cards so don't worry.
We have noticed that the fiberglass is a superior material, but many cars don't see much action in the rain, and the OEM cards have held up for over 30 years in some cases. We wanted to make an inexpensive way to make your doors look like new for much less. Leaving you more money for other things you need. So we set out to replicate the the factory style door panels. So who is interested in a new set of door panels? Early, late and with a variety of colors What do you need? We plan to be able to start shipping end of Jan early Feb. Note the panel shown is the fiberglass more pics to come as we progress. Attached thumbnail(s) |
Mikey914 |
Jun 5 2016, 06:42 PM
We have finally got the process selected and are proceeding to the tooling phase for the door panel GB. It's taken longer than we wanted as we originally hoped to work this out with our fiberglass provider. Unfortunately this did not work out, and we have committed to the tooling to make these out of a just as durable ABS plastic that can withstand the water, and make an OEM looking panel. We have added the nut plate that was not previously on the fiberglass ones. We also include all 3 upper mounting tabs attached to allow you to pop them right in.
We are in the pre-buy phase. What this means is that they can take 4-6 weeks before you have in hand, but you lock in your cost. If the costs go up, and they may a little, you are buying at the lower cost just like we did with the dashes. So if you plan to replace your door panels now's the time. These are sold without the door clips in them, but we have available if you need them. You can reuse yours or we can sell you more. Thanks for your support, so we can make these parts more reasonably. You can find these here - http://www.shop.914rubber.com/Door-pannel-...der-914DPGB.htm As far as RS panels we have added the option. Thanks to all for your patience, these are finally moving forward. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:57 PM |
