bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,560 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
EDIT:
So I picked up about 1000 lbs of parts. Really, cause like I needed them. All three sets of front hubs are spoken for. Getting the first set of rears cleaned up and will install bolts. Here is what I learned so far about the hubs. The rear hubs are drilled and tapped to take bolts that thread in from the back side. Fronts also use thread in hex head bolts that have had the heads ground round to fit flush with the hub. The fronts take 911 "innie" type grease caps that are not included which are available through Pelican at $50.50 each. There are several sets of mono block caliper adapters to adapt bigger brakes to front 3" or 3.5" bolt spacing and rear 914 and 911 trailing arms. I will get the rusted parts cleaned up. Hard to tell from the pics but there are sets of rear caliper spacers for converting rear calipers to use vented rotors. Mono block adapters to add big brakes to 914 or 911 struts. 3 sets of front five lug billet hubs, 5 -1/2 sets of redrilled rear 5 lug hubs. Some of you may recall the CNC machined hubs first offered by Brad Roberts. The person who did them has offered his remaining stock to me to sell off. Seems that Brad left him holding the bag after promising to buy several sets. No big surprise there. These would bolt up to a 914 strut directly with no modifications. It is a package deal and I have to take them with a lot of other 5 lug conversion parts like redrilled rear hubs with allen bolts installed from the back side, redrilled 914 rotors to match. Also are available are the rear caliper spacers to allow use of vented rotors. I will have to figure reasonable pricing. I should have pictures later today. Attached image(s) ![]() ![]() ![]() ![]() ![]() |
Korijo914 |
Newbie ![]() Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None ![]() |
Bruce,
I have been waiting for a set of the 5 lug hubs for a long time. I was supposed to get some from Brad Roberts when they first came out. Do you have a set for me? I have been wanting some for me for the longest time. I will put my order for a rear set, too, if you are going to make them also. Let me know when they are available, ASAP, please. Thank you for your time, korijo |
bdstone914 |
Bruce, I have been waiting for a set of the 5 lug hubs for a long time. I was supposed to get some from Brad Roberts when they first came out. Do you have a set for me? I have been wanting some for me for the longest time. I will put my order for a rear set, too, if you are going to make them also. Let me know when they are available, ASAP, please. Thank you for your time, korijo I will be getting everything in the pictures above. There are three sets of front hubs and 5 sets of rear hubs. You will be the first in line. I do have one set of rear trailing arms that are powder coated. I can install bearings, hubs and pivot shafts is you are interested in a bolt on package. I will have to work up a price for that. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Bruce, I have been waiting for a set of the 5 lug hubs for a long time. I was supposed to get some from Brad Roberts when they first came out. Do you have a set for me? I have been wanting some for me for the longest time. I will put my order for a rear set, too, if you are going to make them also. Let me know when they are available, ASAP, please. Thank you for your time, korijo I will be getting everything in the pictures above. There are three sets of front hubs and 5 sets of rear hubs. You will be the first in line. I do have one set of rear trailing arms that are powder coated. I can install bearings, hubs and pivot shafts is you are interested in a bolt on package. I will have to work up a price for that. Those using screw in studs? If so I had used BBS Racing studs in the past. I can find my source if you don't have one. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:32 AM |
