sdoolin |
Member ![]() ![]() Group: Members Posts: 366 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
I have searched - cannot find much on aftermarket CHT Gauges.
I am building a 2056 that will run dual Dells - would like to install a quality CHT gauge and wondering what others have used. |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,925 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I'm running a Dakota Digital.
I think there are at least several others here as well. I think it has a good reputation, and I'm generally happy with it. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm running a Dakota Digital. I think there are at least several others here as well. I think it has a good reputation, and I'm generally happy with it. Good stuff. FWIW, I found the VDO to be "somewhat" accurate if coupled to the Dakota sender. Does Dakota still offer the 12' lead, only? |
BeatNavy |
I'm running a Dakota Digital. I think there are at least several others here as well. I think it has a good reputation, and I'm generally happy with it. Good stuff. FWIW, I found the VDO to be "somewhat" accurate if coupled to the Dakota sender. Does Dakota still offer the 12' lead, only? No, in the 14mm spark plug size they only offer 18' lead, I believe. That fits the stock 914 plug, otherwise you're trying to make the other one fit, which is not ideal. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:53 PM |
