Groosh |
Member ![]() ![]() Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest ![]() |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Okay, jump pin 85 at the dual relay to the negative battery post. Redo same test as above.
Lo-Fi Version | Time is now: 3rd April 2025 - 06:58 PM |
