> BUILD-OFF CHALLENGE: Rightpedals 74, 914 challenge build
rightpedal
post Sep 27 2015, 07:45 AM
rightpeda;
Hi all
Steve here in Maryland. I just got notified that I am in for the 914 challenge. I will post pics as soon I see how the moderators of the challenge want to proceed.
Ok maybe one teaser....
And maybe another.....
This aint gonna be pretty!
Steve
rightpedal
post Jun 12 2016, 07:56 PM
rightpeda;
A looooooog over due update.
I bought a radiator fan combo
A Subaru 3.0, 5mt trans, computer, starter, harness, and mounts(Crazy Rays pickurpart)
clutch slave (luk from rockauto)
honda clutch master (luk rockuto)
clutch kit from ebay
chunk of 1/4 aluminum
Started cleaning up the floor and adding the tunnel for the cooling tubes.
Attached Image Attached Image Attached ImageAttached ImageAttached Image
I used an old shelving unit for the sheet metal. My thinking is a 1 1/2 deep tray sits just under the factory consul hump. Since I'm not using the factory shifter, wiring harness or fuel lines I might as well take up space with two 1 1/2 tubes. I don't like to use soft lines if i can help it. The plan is to run hard lines under the car with soft connections front and rear.
the Subie 3.0 is from a 2002 outback that was completely caved in on the driver side. No Idea of the millage but everything in the engine compartment pointed to a running engine that had been well maintained.
The glitch was I went back two days later to pull the harness and computer. The car was already crushed. A couple weeks later another 3.0 showed up at a different crazy rays. I love pick ur parts.
The 5mt trans was pulled from a 2002 Impreza that had a pretty hard front impact. This is more of a gamble. The drive pulleys were mangled and it cracked the alt/ac mount. the trans appears to have escaped the the bulk of the impact.
rightpedal   BUILD-OFF CHALLENGE: Rightpedals 74   Sep 27 2015, 07:45 AM
PanelBilly   Is that the parts car?   Sep 27 2015, 08:43 AM
Andyrew   Wow, that is severe... You really going to be ab...   Sep 27 2015, 10:18 AM
mepstein   Once you tear into that body, It's going to ge...   Sep 27 2015, 10:24 AM
LowBridge   Once you tear into that body, It's going to g...   Sep 27 2015, 12:08 PM
Chris H.   Yeah does this one have sentimental value? That...   Sep 27 2015, 04:25 PM
Mikey914   Well, this one will be some work, the good news is...   Sep 27 2015, 04:46 PM
914forme   The water media blasting thing is cool, and seems ...   Sep 27 2015, 04:55 PM
rightpedal   I'm not scared....but yea its ugly. The doors...   Sep 27 2015, 05:22 PM
FourBlades   I fixed one that bad, it can be done. :Qarl: Lo...   Sep 27 2015, 05:25 PM
OU8AVW   Yeah, Steve has some tallent with metal. He has s...   Sep 27 2015, 05:40 PM
Chris H.   Alright then, go for it! Just making sure you...   Sep 27 2015, 05:45 PM
rightpedal   So the full story... I bought a 73 (red car) and ...   Sep 27 2015, 07:54 PM
rightpedal   Some more pics of the blue car   Sep 28 2015, 04:17 AM
rightpedal   Some pics of the red car.   Sep 28 2015, 04:22 AM
Annapolis914   I have seen both vehicles and lucky to have secure...   Oct 4 2015, 04:12 AM
rightpedal   Any body go to the extremes of dissembling the fre...   Oct 31 2015, 04:36 AM
rightpedal   Some of the engine tin got blasted. I acid coated...   Oct 31 2015, 04:57 AM
stevegm   Some of the engine tin got blasted. I acid coate...   Oct 31 2015, 08:43 AM
rightpedal   Some of the engine tin got blasted. I acid coat...   Nov 15 2015, 04:29 PM
rightpedal   BIG DIRECTION CHANGE.............. I bought a ...   Nov 9 2015, 01:30 PM
rightpedal   I guess technically I'm out of the build off. ...   Nov 9 2015, 01:36 PM
Andyrew   I guess technically I'm out of the build off....   Nov 9 2015, 02:02 PM
rightpedal   So i have been clearing house to make room and con...   Nov 9 2015, 01:42 PM
stevegm   If an owner cuts out all the rusty sheet metal on ...   Nov 9 2015, 02:14 PM
rightpedal   That's one jacket I don't want. :D Than...   Nov 9 2015, 02:36 PM
rightpedal   Up date. I have the 75 tucked away in the garage....   Nov 16 2015, 05:16 AM
rightpedal   The wiring harness I now out of the 75. I hacked ...   Nov 16 2015, 05:32 AM
rightpedal   A couple of 75 shots before I bury it in the garag...   Nov 16 2015, 05:39 AM
rightpedal   Disassembled the parts car.   Dec 28 2015, 07:04 PM
rightpedal   Every once and a while my anger issues bubble t...   Dec 28 2015, 07:11 PM
rightpedal   Interior is out.   Dec 28 2015, 07:22 PM
76-914   IIRC, they're phillips and shitty phillips at ...   Dec 28 2015, 07:26 PM
rightpedal   IIRC, they're phillips and shitty phillips at...   Dec 29 2015, 12:22 PM
rightpedal   Enough with the threats......   Dec 28 2015, 07:28 PM
rightpedal   Dad standing with my very own sad little "Por...   Dec 28 2015, 07:31 PM
rightpedal   Got the 1/4 started. Not bad at all. A little rus...   Jan 16 2016, 06:08 AM
Annapolis914   looking good might drop by today as I will be out ...   Jan 16 2016, 06:27 AM
oldie914   The steering wheel and horn button in the blue car...   Jan 23 2016, 09:29 AM
rightpedal   I think the horn button is an original porsche par...   Jan 26 2016, 05:09 AM
RJMII   I think the horn button is an original porsche pa...   Jan 31 2016, 11:30 PM
rick 918-S   Hey, the jacket is cool and all but it is does sym...   Jan 31 2016, 11:03 PM
rightpedal   A looooooog over due update. I bought a radiator...   Jun 12 2016, 07:56 PM
rightpedal   I did a quick clean up to the 3.0 Made a blo...   Jun 12 2016, 08:08 PM
rightpedal   Simple....pattern, drill, jig saw, hole saw, file....   Jun 12 2016, 08:10 PM
Andyrew   Simple....pattern, drill, jig saw, hole saw, file...   Jun 13 2016, 08:03 AM
jimkelly   plate is looking great. jig saw, huh :)   Jun 13 2016, 05:40 AM
76-914   Wow! You stole that drive train. :Qarl: Your ...   Jun 13 2016, 08:25 AM
rightpedal   Wow! You stole that drive train. :Qarl: Your...   Jun 13 2016, 05:00 PM
914350   Way cool...I love the tunnel modification.   Jun 13 2016, 09:01 AM
Andyrew   I also love the center tunnel mod! Be sure y...   Jun 13 2016, 11:11 AM
rightpedal   I also love the center tunnel mod! Be sure ...   Jun 13 2016, 05:06 PM
Andyrew   Are you going to do stainless or aluminized(condui...   Jun 13 2016, 10:07 PM
rightpedal   I have not committed one way or the other. It is ...   Jun 14 2016, 04:47 AM
Andyrew   I have not committed one way or the other. It is...   Jun 14 2016, 08:34 AM
rightpedal   Woooooftaa I just bought a couple of mounts for th...   Jun 14 2016, 04:54 AM
jd74914   Aluminum (non-heat treated so T-0 condition) tubin...   Jun 14 2016, 05:08 AM
rightpedal   Oooo hadn't thought of that! I will do so...   Jun 14 2016, 07:13 AM
rightpedal   Big news I'm moving across the country. This ...   Oct 30 2016, 06:35 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:27 AM
