North Coast Jim |
Member ![]() ![]() Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
After much time and expense I've thrown in the towel on rebuilding these high mileage units. Started with 4 axles and got it down to two what I thought serviceable units, actually they were what was left after inspecting the others. Trying today to assemble them has not produced anything except frustration. Watched Van Swenson U Tube posting on the subject and thought it possible. CV's cleaned and rebuilt properly and assembled on the axle. No amount of effort along with a large amount of foul language will get the C clip to stay within the groove. Arghhhhh !!!!! Tried it on two CV's with different components and the same result. Given up. So...................are there suppliers of finished 914 Axles with CJ Joints out there ??
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
I thought I read somewhere (probably on this board) that the OEMs from a dealer (914-xxxx-xxxx-03 to replace 914-xxxx-xxx-01 and -02) use type one CVs, which, I think, does not have a machined lip/step to accommodate the gasket. I think tangerine mills this step into type 1 CVs, do those from the dealer have the same step? (IMG:style_emoticons/default/beerchug.gif) cjl Is that a fact or a guess? The step is machined in on the new axles from Porsche. Check my unboxing vid and you'll see it when the cover comes off. |
theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
I thought I read somewhere (probably on this board) that the OEMs from a dealer (914-xxxx-xxxx-03 to replace 914-xxxx-xxx-01 and -02) use type one CVs, which, I think, does not have a machined lip/step to accommodate the gasket. I think tangerine mills this step into type 1 CVs, do those from the dealer have the same step? (IMG:style_emoticons/default/beerchug.gif) cjl Is that a fact or a guess? The step is machined in on the new axles from Porsche. Check my unboxing vid and you'll see it when the cover comes off. Mark-neither, just a question. I'm not knowledgable enough to state many things as fact the bit about -03 to replace -01 and -02 came from a P dealer website- suncoast maybe? Cuddy-thanks for posting the vid doing a little more reading it is my understanding type 1's max angle of deflection (don't know if that's the right term almost positive it's not - there's that not enough knowledge again) is 17 degrees while the originals -type ?'s (see above) allow for 22 degrees. something about different size balls and cages can anyone comment on the 'angle of deflection' of the new units from Porsche? (IMG:style_emoticons/default/beerchug.gif) cjl |
Lo-Fi Version | Time is now: 28th June 2024 - 10:57 PM |
