> Turn signals, won't work
arkitect
post Sep 21 2015, 11:49 PM
I'm just about an idiot when it comes to electrical. Is there a simple cure for my lack of turn signals on my 73? And before you say look at the electrical diagram....forget it. Too small for my old eyes to read much less figure out.
They use to work, but over time don't anymore. Is there a ground up front for them, relay went bad, fuse. What is a common thing that I might be able to fix?
Any help would be welcome.
Dave
arkitect
post Jun 14 2016, 07:13 PM
Another turn of events...was running the engine and my grandson was in the car asking me to turn on the lights. I turned them on and thought that was kind of strange, the driver's side went up with a slight delay followed by another delay then the passenger side. Then about 30 seconds later, there starts smoke coming from the dash area. Oh crap...shut it down and disconnect the negative side of the battery.
I pulled the light switch and there was two wires (two into one, grey with red stripe and the other one red) with insulation burned away and touching at one point.
What could have caused this, too much resistance on old wire, bad relay???
It would be nice to actually drive this but don't know where to go from here.
Dave
arkitect   Turn signals   Sep 21 2015, 11:49 PM
914Mike   Fuse is first. Check fuses, bulbs, and sockets for...   Sep 22 2015, 12:23 AM
RobW   There's no easy cure. You have to get in there...   Sep 22 2015, 06:58 AM
Dave_Darling   And before you say look at the electrical diagram....   Sep 22 2015, 09:27 AM
Spoke   I know you don't want to look at an electrical...   Sep 22 2015, 11:21 AM
arkitect   The turn indicator lit up for a few seconds but no...   Sep 22 2015, 10:42 PM
arkitect   I thought I might be onto something. Cleaned the g...   Sep 28 2015, 09:34 PM
arkitect   The 3 wires are the ones to the headlight motor. D...   Oct 3 2015, 12:15 AM
Dave_Darling   The 3 wires are the ones to the headlight motor. ...   Nov 20 2015, 09:24 PM
toolguy   Front grounds are by the back of the headlights, r...   Oct 3 2015, 12:31 AM
arkitect   Which relay is the emergency? Connected to the t...   Nov 20 2015, 03:57 PM
dirk9141973   Which relay is the emergency? Connected to the ...   Nov 20 2015, 04:06 PM
arkitect   It seems that there is a bad relay, stuck open or ...   Nov 20 2015, 04:17 PM
arkitect   Thanks DD for your responses, much appreciated. D...   Nov 20 2015, 11:23 PM
orthobiz   Couldn't it be at the steering column? Remove ...   Nov 21 2015, 07:32 AM
arkitect   Another turn of events...was running the engine an...   Jun 14 2016, 07:13 PM
arkitect   a picture. Dave   Jun 14 2016, 07:19 PM
whitetwinturbo   :popcorn: :popcorn: :popcorn:   Jun 14 2016, 11:08 PM
- Lo-Fi Version Time is now: 26th April 2025 - 09:03 PM
