New GB - Heater cables - CORRECT LENGTH - 70-74, YOU NEED THIS!, These will be $24 (+free nipples) for the GB List is over $38 and mine fit |
Mikey914 |
Jun 15 2016, 10:42 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Again, I've been asked to make correct length heater cables. Apparently the ones on the market are a little too short. These have to be exactly the correct length otherwise they don't reach, and if they are too long the bind up in the flapper arm assembly and will not allow full travel of the flapper, making your heat on not fully on when selected.
These will be nylon coated cables pre-bent for the install at the lever. I've also included 2 free heater cable nipples to seal up the tubes while you are there. So, who's interested? These will be ready in about a week. And who can resist free nipples? Making the 70-74, and the 75-75 version Attached thumbnail(s) Attached image(s) |
Mikey914 |
Jun 16 2016, 10:28 AM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these.
How can you tell? Looks like an appearance group lever, but that could be later. |
76-914 |
Jun 16 2016, 06:47 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these. How can you tell? Looks like an appearance group lever, but that could be later. Mark, I assume it is because it came off my '73 after it decided it liked H2O more than O2. (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Jun 17 2016, 01:13 AM
That's good, because it it is, I have the one from my 75 and I would have the 2 parts to make these. How can you tell? Looks like an appearance group lever, but that could be later. Mark, I assume it is because it came off my '73 after it decided it liked H2O more than O2. (IMG:style_emoticons/default/biggrin.gif) Duhh! I forgot...... Thought there was some magic way that you could tell from the picture because I was stumped. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:09 PM |
