mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,255 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
In my build thread, there were a couple brief comments about replacing the longs without cutting the rear fender. I really like this idea, but need to figure out how to execute it.
Rick, I was hoping you might expand on your original comment... ![]() So P331, the inner wheelhouse, needs to go in- and of course this means the suspension console has to go in with it. There not enough space between the fender and the console to get a torch in there. I can only think of one way to do this... Before I started cutting out the rust, I made a jig that bolts to the trans mounts and engine mounts, and locates the suspension. So I would: 1) Clamp P331 on to the car, drill to locate, then sheet-metal screw it in place. 2) Install my jig, locate the console, and sheet-metal screw it in place. 3) Disassemble everything 4) Weld the console to P331. 5) Weld P331 with console to the car. That's plan A. Plan B is to remove the fender. Which plan would you go with? |
Lo-Fi Version | Time is now: 28th June 2024 - 11:52 PM |
