Installing bearing races in front hubs with dry ice or heat, Anyone try it? |
bdstone914 |
Jun 19 2016, 07:10 AM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have always found these to be a PITA to install. I have tried installing the rear bearings after freezing them and cant see any difference.
If expansion and contraction are proportional to the temperature then dry ice at -109 F should make a big difference. Used in combination of putting the 911 front hub in the oven at 250-300 degrees I am hoping the races will drop right in. Anyone tried it or have an easy method without the proper too size puller tools? |
76-914 |
Jun 19 2016, 12:37 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Or the correct O.D. Harbor Freight impact socket and a hammer. And Dave said it. Start square. You can hear and feel if it is square by the sound of the hammer striking.
Lo-Fi Version | Time is now: 27th December 2024 - 08:55 AM |
