cal914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
I recently had our 1.7 serviced and they reset the gaps in the tappets but now the engine seems to make a rattle noise now,something it didn't do before hand they are experienced so i doubt that they set the wrong gaps but somethings changed
Thanks Brian |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,283 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. Yep.... OE 2.0 exhaust valves are sodium filled. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:02 AM |
