> My First Hiccup, finally put this to bed after the 3rd try
76-914
post Jun 6 2016, 08:08 AM
When we returned from Rt66 '16 I pulled my exhaust system down for a little trimming and noticed water in the left bank muffler! (IMG:style_emoticons/default/WTF.gif) We did drive through a ton of water on that trip. Then when returning from Costco yesterday it acted as if it were starved for fuel when it stumbled during acceleration. The fuel filter was the same one that came on the engine so I ordered another one. When I looked at the filter to check which one I had I noticed the coolant level in the expansion tank/reservoir had dropped. Well, there you are. Head gasket time. Now, I'm wondering if the stumble was due in fact to the head gasket failing? Decisions; should I fix this one which presently has ~ 185K or buy a JDM replacement. After perusing the net I found a few peep's whose JDM experience was less than stellar. Apparently it is a crap shoot as to what you get and the 40-50K avg mileage is (IMG:style_emoticons/default/bs.gif) . So, for about 1K I can pick up another engine and hope I bought a good one or open this one up and hope that is all it needs since it wasn't overheated. What does the the Wasser family think?
EDIT: It's an EZ30D 6cyl
914forme
post Jun 20 2016, 04:26 PM
But you could also use Loctite 518 which is anaerobic sealer, so it cures with the absence of air. = Between machined surfaces. Case halves, transmission halves, oil pump to engine etc.... have a tube on order as I normally keep yamabond around, It is convent stop for me. Amazon is even more convent. And I am not tempted to by a motorcycle.
Stuff keeps in a tube much longer than Ultra-gray.
Or any of the Jap brand XXXX-bond stuff. So you have Fujibond, Hondabond, yamabond, etc..... Lets rebrand the same stuff 100 times and go from there. BTW, VW has the same stuff also, so I am sure Porsche does as well, more than likely have the four rings logo on it. Same stuff you get for $1000 a tube to seal you Lambo (IMG:style_emoticons/default/lol-2.gif)
post Jun 21 2016, 08:00 PM
QUOTE(914forme @ Jun 20 2016, 03:26 PM) *
I think your on to something with the re-branding thought, Stephen. I wonder if the "grey" agent Fuji, Honda or Triple Bond, is the same as the German product "Dirko". It lists the same sealing qualities. I have the locktite stuff as well but it might be too old to trust. Have you ever used any CURIL sealing products? It's another German product. I'm still waiting on my gasket set. (IMG:style_emoticons/default/mad.gif) My order is "being processed". (IMG:style_emoticons/default/confused24.gif)
76-914   My First Hiccup   Jun 6 2016, 08:08 AM
'73-914kid   As you know, I like doing stuff myself.. Just my...   Jun 6 2016, 09:33 AM
ThePaintedMan   Almost 100% the head gasket, and the resulting iss...   Jun 6 2016, 12:15 PM
Chris H.   You could do the head gasket no problem Kent. Doe...   Jun 6 2016, 03:29 PM
colingreene   Its because they are somewhat terrible motors.   Jun 6 2016, 05:25 PM
jimkelly   a head install video i like ddFsFfiyOvg   Jun 6 2016, 05:43 PM
malcolm2   a head install video i like ddFsFfiyOvg needs ...   Jun 9 2016, 12:36 PM
76-914   Almost 100% the head gasket, and the resulting is...   Jun 6 2016, 05:57 PM
ThePaintedMan   Cometic gaskets are all MLS, or multi-layered stee...   Jun 8 2016, 11:56 AM
rick 918-S   Cometic gaskets are all MLS, or multi-layered ste...   Jun 8 2016, 08:33 PM
effutuo101   That sucks. But from what I have read, pretty simp...   Jun 6 2016, 06:09 PM
76-914   That sucks. But from what I have read, pretty sim...   Jun 6 2016, 06:43 PM
rnellums   I'll be interested in what you find. The EZ30s...   Jun 6 2016, 07:44 PM
76-914   I'll be interested in what you find. The EZ30...   Jun 6 2016, 08:51 PM
Chris H.   Yeah you need a new chain...it'll be stretched...   Jun 6 2016, 08:50 PM
r_towle   What is water doing in the car?   Jun 6 2016, 08:55 PM
DBCooper   What is water doing in the car? That's kind ...   Jun 6 2016, 09:06 PM
r_towle   What is water doing in the car? That's kind...   Jun 6 2016, 09:41 PM
flmont   And I thought the 2010 3.6's were non-interfe...   Jun 6 2016, 09:29 PM
Chris H.   And I thought the 2010 3.6's were non-interf...   Jun 6 2016, 09:35 PM
914-300Hemi   sorry to hear about the engine troubles Kent. At l...   Jun 6 2016, 09:38 PM
oldschool   Big Boy I know my shop is a bit too far from you, ...   Jun 6 2016, 10:36 PM
rick 918-S   Likely related to the early over heating issue whe...   Jun 8 2016, 07:19 AM
DBCooper   I would say I owe you a set of rears but you built...   Jun 8 2016, 08:23 AM
76-914   You drove it like it was yours, Rick. Proud of ya....   Jun 8 2016, 08:56 AM
rhodyguy   2.5k. Wow. These are units sourced from Subaru by ...   Jun 8 2016, 10:30 AM
76-914   2.5k. Wow. These are units sourced from Subaru by...   Jun 8 2016, 12:34 PM
r_towle   I love how the engine cradle is also the drivetrai...   Jun 8 2016, 01:34 PM
rhodyguy   A thing of back saving beauty.   Jun 8 2016, 04:00 PM
ThePaintedMan   Yup, they don't sound like they'd seal, bu...   Jun 8 2016, 10:25 PM
76-914   I love how the engine cradle is also the drivetra...   Jun 9 2016, 08:03 AM
ThePaintedMan   Yeah, you'd need to find the stock thickness -...   Jun 9 2016, 09:33 AM
Chris H.   I have ONE good mount (and one bad one) you can ha...   Jun 9 2016, 10:17 AM
flmont   I need a engine cradle,..too...!!!...   Jun 9 2016, 05:32 PM
76-914   Thx for the video Jim but mine is a six. I do have...   Jun 10 2016, 10:51 PM
colingreene   Kent is that really the best you have? Obviously i...   Jun 11 2016, 01:40 AM
rick 918-S   Wow! Arnolds tractor oil? :unsure: That thing...   Jun 11 2016, 10:02 AM
914_teener   Wow! Arnolds tractor oil? :unsure: That thin...   Jun 11 2016, 10:36 AM
Chris H.   Sheesh Kent I better finish mine up if you're ...   Jun 11 2016, 11:25 AM
914forme   Poly mounts to the -4 mounting point are easy. I ...   Jun 12 2016, 09:55 AM
76-914   Kent is that really the best you have? Obviously ...   Jun 12 2016, 03:47 PM
914forme   I didn't know where to but those when I made...   Jun 19 2016, 08:29 AM
76-914   OK, this is what I was referring to when I said th...   Jun 12 2016, 10:29 PM
r_towle   See, water = corrosion, just sayin   Jun 12 2016, 11:09 PM
76-914   Well, I'm either a lucky SOB or I missed somet...   Jun 17 2016, 10:26 PM
OU812   Well, I'm either a lucky SOB or I missed some...   Jun 19 2016, 10:41 AM
Elliot Cannon   Nope, nope and NO. I'm NOT going to comment ...   Jun 17 2016, 10:49 PM
914_teener   Subaru Effed up......that's the answer.   Jun 17 2016, 10:59 PM
DBCooper   See, water = corrosion, just sayinOh, so that...   Jun 17 2016, 11:21 PM
76-914   See, water = corrosion, just sayinOh, so that...   Jun 18 2016, 09:06 AM
Chris H.   So...we're getting new hoses then :D ? Hey g...   Jun 18 2016, 09:20 AM
DBCooper   Huh, now that you mention it I wonder how many T4 ...   Jun 18 2016, 09:27 AM
DBCooper   In the first 100K miles, sure, after 150K miles pr...   Jun 19 2016, 10:53 AM
OU812   In the first 100K miles, sure, after 150K miles p...   Jun 19 2016, 11:51 AM
76-914   So...we're getting new hoses then :D ? Hey ...   Jun 19 2016, 12:23 PM
Chris H.   I just start began searching for SS pipe last ni...   Jun 19 2016, 07:45 PM
DBCooper   It's true carbs would be pretty interesting bu...   Jun 19 2016, 12:56 PM
Andyrew   Wow that sludge issue is Crazy. Those multi layere...   Jun 19 2016, 01:05 PM
914forme   Here you go   Jun 19 2016, 07:59 PM
914forme   But you could also use Loctite 518 which is anaero...   Jun 20 2016, 04:26 PM
76-914   But you could also use Loctite 518 which is anaer...   Jun 21 2016, 08:00 PM
Chris H.   That's a good point...the Permatex stuff does ...   Jun 20 2016, 06:13 PM
76-914   Finally! Gasket set arrived this PM. I need to...   Jun 25 2016, 07:29 PM
76-914   Finished cleaning except the pan and that can wait...   Jun 29 2016, 08:25 PM
76-914   Since I have to wait a few days for 6ea 8mm allen ...   Jul 7 2016, 07:18 PM
914forme   The right chain still has slack in it as shown b...   Jul 8 2016, 01:39 PM
76-914   Hah! I flew w/o one of those for years until o...   Jul 8 2016, 02:04 PM
Elliot Cannon   Hah! I flew w/o one of those for years until ...   Jul 25 2016, 08:32 PM
Chris H.   Wow that thing is clean. You're just about re...   Jul 8 2016, 04:42 PM
76-914   It's back together. Is it healed? We'll se...   Jul 16 2016, 03:34 PM
rhodyguy   Admerable skills. Good work. When do you plan on c...   Jul 17 2016, 08:57 AM
76-914   Got the engine back in Sunday and she fired right ...   Jul 25 2016, 03:19 PM
mgp4591   Got the engine back in Sunday and she fired right...   Jul 25 2016, 08:04 PM
Chris H.   Fuel starvation? Weird. Did you buy a JDM? Lo...   Jul 25 2016, 07:37 PM
76-914   Got the engine back in Sunday and she fired righ...   Aug 11 2016, 03:59 PM
76-914   I began to reassemble (again :angry: ) the timing...   Aug 27 2016, 06:43 PM
Chris H.   Hey mail it to me if you're gonna throw it in ...   Aug 27 2016, 07:31 PM
76-914   Hey mail it to me if you're gonna throw it in...   Aug 28 2016, 09:33 AM
Chris H.   As soon as I shake the Cobwebs out of my head thi...   Aug 28 2016, 07:46 PM
rhodyguy   I had never realized that the battery had to be re...   Aug 28 2016, 01:37 PM
76-914   I had never realized that the battery had to be r...   Aug 28 2016, 01:59 PM
rhodyguy   I haven't given up yet. I don't want to be...   Aug 28 2016, 02:11 PM
76-914   Whew! That was a blast. Not! >:D But ...   Aug 30 2016, 08:34 PM
76-914   Well, after my last post I found that I had NOT fi...   Dec 5 2016, 03:48 PM
rhodyguy   Great Kent! Btw chris, I opted for choice #3....   Dec 5 2016, 04:03 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 09:23 PM
