jack20 |
Member ![]() ![]() Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California ![]() ![]() |
I need to remove and replace the poly bushings from my rear trailing arms. They are squeaking and popping and I can't stand it anymore.
The bushings are held in place with JB Weld. The arms are freshly powder coated and have new bearings in place so I don't want to use a torch to melt the JB Weld. Any suggestions on how to remove the bushings and clean up the inside diameter of the trailing arms without using a torch? Thanks in advance. Jack |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
JB weld to hold bushings in place? (IMG:style_emoticons/default/WTF.gif)
cut off the end or drill them out with a hole saw then core out the remainder. the tolerances for bushing insertion is so small you almost need to take the trailing arms to a machine shop to make sure the mating surface is smooth enough for the new bushings to be pressed in |
jack20 |
JB weld to hold bushings in place? (IMG:style_emoticons/default/WTF.gif) cut off the end or drill them out with a hole saw then core out the remainder. the tolerances for bushing insertion is so small you almost need to take the trailing arms to a machine shop to make sure the mating surface is smooth enough for the new bushings to be pressed in These are poly bushings and JB Weld is called for in the install instructions. The machine shop is certainly an option if I can't do this on my own. Thanks. |
jmitro |
These are poly bushings and JB Weld is called for in the install instructions. The machine shop is certainly an option if I can't do this on my own. Thanks. that's interesting; I've never heard of that. Just for my own information, do you have a link for the vendor's instructions? Does the vendor recommend a torch for removal? |
jack20 |
[quote name='jmitro' date='Jun 27 2016, 04:12 PM' post='2364729']
[quote name='jack20' post='2364642' date='Jun 27 2016, 02:00 PM'] These are poly bushings and JB Weld is called for in the install instructions. The machine shop is certainly an option if I can't do this on my own. Thanks. [/quote] that's interesting; I've never heard of that. Just for my own information, do you have a link for the vendor's instructions? Does the vendor recommend a torch for removal? [/quote PM me and I will give you the info. Jack |
Lo-Fi Version | Time is now: 29th June 2024 - 12:50 AM |
