Removing poly bushings from trailing arms, JB welded in place |
jack20 |
Jun 27 2016, 11:45 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I need to remove and replace the poly bushings from my rear trailing arms. They are squeaking and popping and I can't stand it anymore.
The bushings are held in place with JB Weld. The arms are freshly powder coated and have new bearings in place so I don't want to use a torch to melt the JB Weld. Any suggestions on how to remove the bushings and clean up the inside diameter of the trailing arms without using a torch? Thanks in advance. Jack |
mgp4591 |
Jun 28 2016, 10:18 PM
914 Guru Group: Members Posts: 5,390 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Maybe a silly question, but did you install grease zerks to lube the bushings so noise would be minimal or absent? I was advised by another on this thread that this was the solution and the poly bushings would keep things crisp out back...
But you've already done the deed so this point is moot. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 29th June 2024 - 12:57 AM |
