Accelerator cable, Collapsing at the cluster |
74ravenna |
Jun 29 2016, 04:20 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
Hi,
In the process of an engine swap. I went from FI to carbs. I was able to connect the accelerator cable to the pulley at the engine/carbs but at the pedal cluster the cable collapses. It looks like a Fork Bolt (Haynes parts breakdown) is supposed to slide over the cable somehow. Is that correct? My far-sightedness certainly makes it challenging! TIA Steve |
Darren C |
Jun 30 2016, 05:15 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
I had a similar experience. It was slack in the cable. Try pulling more cable out at the carb end then clamping it in the lever. This should tighten up the slack at the pedal end and stop the clevis from sagging.
You also need to check the pedal bushes aren't worn out too. Good luck |
Lo-Fi Version | Time is now: 28th June 2024 - 11:51 PM |
