slotty008 |
Member ![]() ![]() Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None ![]() ![]() |
The car just came back from the bodyshop to replace the floor underneath the inner firewall and the front trunk floor. The stuff from Restoration Design is great.
But behind the passenger seat there's still a gap between the inner firewall and the floor. Is it necessary to weld this for the stiffness of the car or can I just use some epoxy to close the gap? ![]() |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
The portion behind the inner firewall is the portion enclosed between the two firewalls.
The portion in the red circle. Did they take pictures? ![]() The pictures your showing us is in the yellow circle. If they can assure you the flange in the yellow circle isn't consumed by the rust worm. Then it's a different story. Did they do any kind of rust treatment/neutralization ? |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,283 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
The portion behind the inner firewall is the portion enclosed between the two firewalls. The portion in the red circle. Did they take pictures? ![]() The pictures your showing us is in the yellow circle. If they can assure you the flange in the yellow circle isn't consumed by the rust worm. Then it's a different story. Is there a larger cross section view of this area on hand, I'd like to understand this area more completely Thanks |
Lo-Fi Version | Time is now: 28th June 2024 - 11:23 PM |
