Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I have the popular front hood shox kit on my 914 but I have issues with it. The shox do hold the hood up in the garage quite well. But in the environment with wind, it fails to hold the hood up. The geometry seems off as if the hood is pushed down an inch or 2 it loses all shock resistance and falls very rapidly.
I find it embarrassing to have to put a length of wood to wedge the hood open while I fuel but even more embarrassing to pump with one hand and hold up the hood with the other. These are new shox. Just purchased and installed a few months ago. I think I've installed them correctly. If the hood is pulled down a couple of inches, it flies down with no resistance. The kit seems well designed but the geometry seems off. The shocks on my 911 front hood provide resistance no matter how open the hood is. Question then: What do I have to do to eliminate the "falling hood" syndrom? Add the original spring? Did I do the installation wrong? Help!! My car as it sits. The gas station I stop at always has wind blowing the hood closed. The wooden stand is absolutely necessary with this shox kit. I've gotten hit too many times with a falling hood while refueling. ![]() Here's Camp914's installation. Mine is the same as this. ![]() Here's how Sir Andy solved the hood shock. The geometry here looks better than mine. ![]() Here's another shock (I think it's a shock) solution. ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,442 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Ha ..these are rejected jet parts, 5 locking balls in a groove you can huff and you can puff the hood will stay in place...they had to be replaced because they had steel balls instead of stainless....the sleeves slides back disengaging the balls.
Prop rods can be a bit unstable in windy conditons.. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 1st July 2024 - 02:16 AM |
