7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
A problem has recenly developed and I can't figure it out. The car starts up easy and on the first crank. I let it warm up a few minutes and drive....It drives fine as it's warming up.
Then after about 15 or 20 minutes the engine starts developing a shudder. Idles fine but and can run ok under low load but under some load the #4 cylinder starts popping and firing up through the carb. feels like it's running 3 cylinders and wasting gas. It's been suggested I do a compression test but I'm thinking if the engine runs great cold and while warmin up; the compression should be ok. Is there a case where comprression is ok when cold but low when hot? Can't figure out why car runs great when starts f'n up. 1.7 with dual weber 40 IDFs |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Look at the valve tips when each cylinder is on TDC. If one of the valves on #3 is sitting with the tip closer to the head, it's a dropped valve seat.
With zero compression, the problem is almost certainly serious enough that to fix it you will need to drop the engine and remove the head. At a minimum. --DD |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Look at the valve tips when each cylinder is on TDC. If one of the valves on #3 is sitting with the tip closer to the head, it's a dropped valve seat. With zero compression, the problem is almost certainly serious enough that to fix it you will need to drop the engine and remove the head. At a minimum. --DD (IMG:style_emoticons/default/agree.gif) It needs to come out and anything you do will be easier once it is out. Don't waste your time, just drop the engine. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:49 AM |
