> Fuel line grommets, Can't find
Cornerlot
post Jul 12 2016, 07:50 AM
I'm new to 914's, previously I've just fooled with 911's.
I now have a '70 914-6 with the fuel tank out and need to replace the rubber grommets for the fuel lines. These are where the 2 fuel lines (different O.D.'s) enter the tunnel under the tank, both going through their own OVAL holes (one line per hole).
Any ideas? The closest I found are the PN 111957861 oval grommets for the brake reservoir lines and fuel in the 914-4 engine bay. The PET shows both a NLA single large oval grommet in some cars set up for 2 lines, or a un-pictured NLA grommet PN 99970209550 for single lines.
Steve
Mikey914
post Jul 12 2016, 10:36 AM
The rubber man
Yep, I have the rear ones. If you can't find what you need. I can probably make it. Just let me know.
Cornerlot
post Jul 12 2016, 11:24 AM
QUOTE(Mikey914 @ Jul 12 2016, 12:36 PM) *
The round ones won't work, they are larger and oval. The engine shelf ones may work. Right now I have the stock lines, so angled 8mm and 10mm should work.
Steve
- Lo-Fi Version Time is now: 31st October 2024 - 08:25 PM
