> fuel pump relocation....Where?
surfdogskier
post Jul 19 2016, 06:21 PM
Hey guys,
Got to play around with my 914 yesterday. With the help of my neighbor, we were able to figure some things out.
The fuel pump is mounted in the wrong spot. Mine was the one that was zipped tied from a previous post. Really stupid. It should be mounted on the passenger side fender area under the car from what I can tell. However, those rubber mounts at hold the bracket on are broke. No way to attach it back. Pelican parts does not have these any more.
Is it safe to install it in the engine compartment underneath the PCM or does this area get to hot? Any other places you guys would recommend?
Thanks,
Jason
914_teener
post Jul 20 2016, 09:13 AM
Both pictures show a two port fuel pump and mounted on the rear fire wall. I have had mine there for 7 years and driven in over 110 degree heat and no issues.
It is less work to locate it there than underneath the rack cover IMHO.
I mounted mine with riv nuts and the stock hardware.
Your choice.
surfdogskier   fuel pump relocation....Where?   Jul 19 2016, 06:21 PM
914_teener   Firewall underneath on the passenger side. Perfect...   Jul 19 2016, 06:27 PM
rhodyguy   Definitely NOT in the engine compartment.   Jul 19 2016, 06:32 PM
Elliot Cannon   Definitely NOT in the engine compartment. My pum...   Jul 19 2016, 11:09 PM
Rand   Definitely NOT in the engine compartment. My pu...   May 2 2017, 05:05 PM
Tom_T   Hey Jason, Do yourself a favor now, & just do...   Jul 19 2016, 06:33 PM
Mark Henry   You can get the pump isolators from aircooled.net ...   Jul 19 2016, 06:54 PM
surfdogskier   Thanks guys! I will definitely look into the ...   Jul 19 2016, 06:55 PM
surfdogskier   Went to AutoAtlanta.com and they had it for 50% of...   Jul 19 2016, 07:16 PM
zambezi   UH-OH   Jul 19 2016, 10:24 PM
JawjaPorsche   This has been debated many times on this forum. F...   Jul 20 2016, 03:56 AM
rhodyguy   Elliot, you're saying the FP in the yellow 6 w...   Jul 20 2016, 06:55 AM
Elliot Cannon   Elliot, you're saying the FP in the yellow 6 ...   Jul 22 2016, 08:45 PM
napasteve   Jawja, Thanks for posting that fuel pump picture....   Jul 20 2016, 07:54 AM
Jeff Bowlsby   There was an October 1973 factory service bulletin...   Jul 20 2016, 08:28 AM
worn   There was an October 1973 factory service bulleti...   Jul 20 2016, 02:42 PM
napasteve   Jeff, I would have been happy to leave the fuel pu...   Jul 20 2016, 08:58 AM
Jeff Bowlsby   Do you know of such a 2-port pump? Negatory on...   Jul 20 2016, 10:28 AM
ClayPerrine   Jeff, I would have been happy to leave the fuel p...   Jul 20 2016, 08:26 PM
914_teener   Both pictures show a two port fuel pump and mounte...   Jul 20 2016, 09:13 AM
napasteve   Clay, is Betty's car running the stock FI? I ...   Jul 22 2016, 07:49 PM
914_teener   This is exactly where mine is. On the rear fire wa...   Jul 22 2016, 09:21 PM
porschetub   Carter pump for carbs mounted on front alloy cross...   Jul 23 2016, 01:46 AM
OU812   It is definitely up for debate but it would seem t...   Jul 23 2016, 09:49 AM
Marv's3.6six   It is definitely up for debate but it would seem ...   Apr 3 2017, 01:50 PM
rhodyguy   That pump pictured is NOT IN the engine compartmen...   Apr 3 2017, 01:24 PM
srreality   Hey guys, Got to play around with my 914 yesterd...   May 1 2017, 06:12 PM
RobW   I've done both the front trunk kit and more re...   May 1 2017, 06:31 PM
r_towle   I've done both the front trunk kit and more r...   May 1 2017, 07:20 PM
TM_Corey   My guy put it here. Is it good to go? The filter...   May 1 2017, 07:32 PM
GeorgeRud   Mine is also mounted as in the previous picture, b...   May 1 2017, 09:03 PM
6freak   I just through mine away :lol4: so over rated   May 2 2017, 02:46 PM
rdauenhauer   Factory Mount :) Easy access, from the front tru...   May 2 2017, 03:10 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 12:39 PM
