surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
Hey guys,
Got to play around with my 914 yesterday. With the help of my neighbor, we were able to figure some things out. The fuel pump is mounted in the wrong spot. Mine was the one that was zipped tied from a previous post. Really stupid. It should be mounted on the passenger side fender area under the car from what I can tell. However, those rubber mounts at hold the bracket on are broke. No way to attach it back. Pelican parts does not have these any more. Is it safe to install it in the engine compartment underneath the PCM or does this area get to hot? Any other places you guys would recommend? Thanks, Jason |
napasteve |
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 504 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California ![]() ![]() |
Jeff, I would have been happy to leave the fuel pump in its original position but this was not possible if you switch to a 2-port pump (as shown in Jawja and my pictures). And lack of availability of the original 3-port pumps forces the switch to the 2-port pump and I'm not aware of a 2-port pump with both ports on one end like the 3-port configuration. Do you know of such a 2-port pump?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Jeff, I would have been happy to leave the fuel pump in its original position but this was not possible if you switch to a 2-port pump (as shown in Jawja and my pictures). And lack of availability of the original 3-port pumps forces the switch to the 2-port pump and I'm not aware of a 2-port pump with both ports on one end like the 3-port configuration. Do you know of such a 2-port pump? Airtex part number E8445 is an aftermarket 2 port pump that provides the same pressure and volume as the stock 3 port pump. I have been running one on Betty's car for about 6 years now with absolutely no issues. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:01 PM |
