daughter's 1.8 won't start, fuel issue? |
porbmw |
Jul 20 2016, 09:28 AM
Senior Member Group: Members Posts: 813 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Daughter was away 2 years, car was parked.
On return, started it up, just fine, but a bit of a stutter. Filled it up completely with fuel, seemed to work fine for an hour or so. Couple days later "dad...the car is running badly, it hesitates". Started it up, a few hesitations/balks. Figured perhaps the fuel filter..so bought a Lordco filter, swapped it out. Turned on ignition. NO fuel seems to be getting through. This is a new one. Turned over repeatedly, no success. Swapped back to old filter in case of crappy filter. Same. Took line off end of filter that feeds engine. Turn on ignition. No "squirt" of fuel, but clearly fuel HAS been getting through filter, as fuel on "that side" when remove. Did same with new filter. Turns over, nothing trying to "catch". About to give up. Car fires up nicely, so go for a one hour drive. Next day. "dad...the car won't start"... Same "no catch, no indication of fuel into engine" Any ideas? AND If it turns out to be a fuel pump issue: a) any recommended source for fuel pump...I suppose 3 port is unlikely, so 2 port? b)IF a 2 port, do I have to relocate pump re configuration of ports? Thanks very much. Paul |
rmital |
Jul 20 2016, 09:31 AM
Northeast optimist Group: Members Posts: 1,952 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
jeez...Big Len just went thru the same thing, got it to Rory's garage, trouble shot it quickly....double relay issue
I know very little about Ljet...just passing on the info |
porbmw |
Jul 21 2016, 09:53 PM
jeez...Big Len just went thru the same thing, got it to Rory's garage, trouble shot it quickly....double relay issue I know very little about Ljet...just passing on the info (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) DING....DING....DING.... We have a winner....(well, Rmital AND Big Len) When I looked at the location of the double relays, it started making sense. I had a @#@#$@# of a time getting the hose off the "front side" of the fuel filter, and in all likelihood nudged the wires and, as a result, one or both of the relays nearby (beneath the battery tray) Thanks, to all. Paul (and daughter Kirsten) BTW Should I mention that she is smart, single and rather attractive. nah.....bunch of wieners |
rmital |
Jul 22 2016, 06:01 AM
jeez...Big Len just went thru the same thing, got it to Rory's garage, trouble shot it quickly....double relay issue I know very little about Ljet...just passing on the info (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) DING....DING....DING.... We have a winner....(well, Rmital AND Big Len) When I looked at the location of the double relays, it started making sense. I had a @#@#$@# of a time getting the hose off the "front side" of the fuel filter, and in all likelihood nudged the wires and, as a result, one or both of the relays nearby (beneath the battery tray) excellent...happy motoring... (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 01:03 AM |
