surfdogskier |
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None ![]() |
Hey guys,
Got to play around with my 914 yesterday. With the help of my neighbor, we were able to figure some things out. The fuel pump is mounted in the wrong spot. Mine was the one that was zipped tied from a previous post. Really stupid. It should be mounted on the passenger side fender area under the car from what I can tell. However, those rubber mounts at hold the bracket on are broke. No way to attach it back. Pelican parts does not have these any more. Is it safe to install it in the engine compartment underneath the PCM or does this area get to hot? Any other places you guys would recommend? Thanks, Jason |
Gunn1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None ![]() |
It is definitely up for debate but it would seem the "Best Place" to mount it would be up front where it eventually evolved and was placed by the factory in later models.
For ease of application relocating somewhere in the engine bay may be easier and stop the vapor lock issue, but in the case of a complete restore I would pick the forward position, or maybe an adaptation and put the pump in the fuel tank where most modern vehicles have there's. The cooler the better. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:38 PM |
