Remove transmission. |
Keith914 |
Jul 15 2016, 01:24 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Need to replace rear crankshaft oil seal. What is least amount of work: drop engine/transmission, or support engine in car and remove transmission?
stugray |
Jul 15 2016, 03:20 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
just did this recently to rebuild my trans:
Jack car up & place on jackstands support engine with floor jack on engine block side of trans interface loosen front motor mounts where bar mates to body (depending on year bolt may have a lot of thread) so that you dont stress rubber mounts at engine when tipping. I removed my exhaust because I have stubs so I didnt have to unbolt from heads You might be able to remove trans with exhaust in place, but mine is aftermarket so your results may be different remove shift linkage from firewall back disconnect clutch cable & speedo cable disconnect ground strap at top of trans disconnect CV joints at trans and put in plastic bags OK to leave them hanging, but some tie them up high Crack all 4 bolts loose that hold the trans in place but do not remove (one above/behind the starter requires two people? and access from engine bay) remove 4X small bolts that hold trans mounts to body (engine&trans will fall at this point if not supported at engine) watch in engine bay as you lower engine/trans a few degrees with floor jack and make sure no interference with rear of engine bay Put trans floor jack under trans, take the weight and trans should slide right off Put jackstand or blocks under engine to hold it (DO NOT leave it on the floor jack) |
mitche |
Jul 29 2016, 02:48 PM
Newbie Group: Members Posts: 6 Joined: 28-July 16 From: Sweden Member No.: 20,233 Region Association: None |
just did this recently to rebuild my trans: Jack car up & place on jackstands support engine with floor jack on engine block side of trans interface loosen front motor mounts where bar mates to body (depending on year bolt may have a lot of thread) so that you dont stress rubber mounts at engine when tipping. I removed my exhaust because I have stubs so I didnt have to unbolt from heads You might be able to remove trans with exhaust in place, but mine is aftermarket so your results may be different remove shift linkage from firewall back disconnect clutch cable & speedo cable disconnect ground strap at top of trans disconnect CV joints at trans and put in plastic bags OK to leave them hanging, but some tie them up high Crack all 4 bolts loose that hold the trans in place but do not remove (one above/behind the starter requires two people? and access from engine bay) remove 4X small bolts that hold trans mounts to body (engine&trans will fall at this point if not supported at engine) watch in engine bay as you lower engine/trans a few degrees with floor jack and make sure no interference with rear of engine bay Put trans floor jack under trans, take the weight and trans should slide right off Put jackstand or blocks under engine to hold it (DO NOT leave it on the floor jack) I just did as above, but the engine and trans will not disengage/separate...... Going crazy here..... Thing is that reason to make thos manouver is due to I think that the flywheel is rusted to the engine (is it even possible?). When I put a gear in, the wheels can turn with no problem. When I try to start the car, the starter cant turn the engine, when I take off the starter it works excellent. And now I cant separate them two.... Tired... (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 06:33 PM |
