> Remove transmission.
Keith914
post Jul 15 2016, 01:24 PM
Need to replace rear crankshaft oil seal. What is least amount of work: drop engine/transmission, or support engine in car and remove transmission?
stugray
post Jul 30 2016, 12:51 AM
Try to actuate the clutch. The Throw out bearing will try to separate the trans from the engine
Keith914   Remove transmission.   Jul 15 2016, 01:24 PM
DavidSweden   Need to replace rear crankshaft oil seal. What is...   Jul 15 2016, 01:42 PM
SLITS   Remove the tranny .... The engine drop will addit...   Jul 15 2016, 01:44 PM
Keith914   Thanks for advice. Will leave engine in place and ...   Jul 15 2016, 02:41 PM
stugray   just did this recently to rebuild my trans: Jack ...   Jul 15 2016, 03:20 PM
mitche   just did this recently to rebuild my trans: Jack...   Jul 29 2016, 02:48 PM
stugray   Try to actuate the clutch. The Throw out bearing w...   Jul 30 2016, 12:51 AM
mitche   Try to actuate the clutch. The Throw out bearing ...   Aug 2 2016, 01:09 PM
The Cabinetmaker   Did you remove all four bolts or nuts from the bel...   Aug 2 2016, 01:23 PM
mitche   Did you remove all four bolts or nuts from the be...   Aug 2 2016, 01:40 PM
stugray   Did you remove all four bolts or nuts from the b...   Aug 2 2016, 04:15 PM
76-914   [quote name='mitche' post='2379589' date='Aug 2 2...   Aug 2 2016, 06:06 PM
Reverend Troublemaker   Except now he stated the engine is out of the car....   Aug 3 2016, 12:28 PM
Jeffs9146   You could try to put it in 5th gear manually and t...   Aug 3 2016, 01:15 PM
mitche   You could try to put it in 5th gear manually and ...   Aug 6 2016, 07:28 AM
stugray   I can with a big hammer turn the flywheel so I ca...   Aug 6 2016, 11:01 AM
mitche   I can with a big hammer turn the flywheel so I c...   Aug 6 2016, 11:16 AM
mitche   [quote name='stugray' post='2381346' date='Aug 6 ...   Aug 6 2016, 12:30 PM
stugray   Well the bottom two bolts are studs (correct wor...   Aug 6 2016, 01:19 PM
76-914   then absolutely :beer2:   Aug 6 2016, 07:40 AM
cuddyk   Congrats! At this point you should be able to ...   Aug 6 2016, 12:46 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:31 PM
