> Remove transmission.
Keith914
post Jul 15 2016, 01:24 PM
Need to replace rear crankshaft oil seal. What is least amount of work: drop engine/transmission, or support engine in car and remove transmission?
Jeffs9146
post Aug 3 2016, 01:15 PM
Ski Bum
You could try to put it in 5th gear manually and turn the output shafts while pulling the trans away from the engine.
mitche
post Aug 6 2016, 07:28 AM
QUOTE(Jeffs9146 @ Aug 3 2016, 01:15 PM) *
Update:
When I put in any gear the driveshafts just turns around just like there is no gear in place.
This makes me believe that the clutch is corroded in "engaged" position, correct assumption?
I can with a big hammer turn the flywheel so I can reach every 13mm nut through the starter hole. Should I remove these 13 mm nuts?
Cheers
Mike
BTW here's the beauty...
stugray
post Aug 6 2016, 11:01 AM
QUOTE(mitche @ Aug 6 2016, 07:28 AM) *
I dont understand that you can turn the FW with a big hammer...
What is stopping you from just leaving the engine stationary (and the FW) and just twisting the trans while it is stuck to the back of the engine?
Cant you just rotate the trans case to reach all the Clutch plate bolts?
If the clutch is engaged (stuck even) and the driveshaft is stuck into the clutch disk, and all 4 bolts are out, what is stopping you from just twisting the trans while it is still attached? (unless the trans driveshaft is frozen too?)
I dont recall any large pins in the trans mating surface that protrude into the engine case.
mitche
post Aug 6 2016, 11:16 AM
QUOTE(stugray @ Aug 6 2016, 11:01 AM) *
Well the bottom two bolts are studs (correct word) so I cannot twist the whole transmission.
Now the 6 bolts from the flywheel are out, and I am going to try to separate the two of them.
Wish me luck
stugray
post Aug 6 2016, 01:19 PM
QUOTE(mitche @ Aug 6 2016, 11:16 AM) *
Ahh... You could have removed those studs by double nutting them and backing them out.
They both usually come out when I go to remove the tranny anyway, so I forgot.
Glad you got it!
Keith914   Remove transmission.   Jul 15 2016, 01:24 PM
DavidSweden   Need to replace rear crankshaft oil seal. What is...   Jul 15 2016, 01:42 PM
SLITS   Remove the tranny .... The engine drop will addit...   Jul 15 2016, 01:44 PM
Keith914   Thanks for advice. Will leave engine in place and ...   Jul 15 2016, 02:41 PM
stugray   just did this recently to rebuild my trans: Jack ...   Jul 15 2016, 03:20 PM
mitche   just did this recently to rebuild my trans: Jack...   Jul 29 2016, 02:48 PM
stugray   Try to actuate the clutch. The Throw out bearing w...   Jul 30 2016, 12:51 AM
mitche   Try to actuate the clutch. The Throw out bearing ...   Aug 2 2016, 01:09 PM
The Cabinetmaker   Did you remove all four bolts or nuts from the bel...   Aug 2 2016, 01:23 PM
mitche   Did you remove all four bolts or nuts from the be...   Aug 2 2016, 01:40 PM
stugray   Did you remove all four bolts or nuts from the b...   Aug 2 2016, 04:15 PM
76-914   [quote name='mitche' post='2379589' date='Aug 2 2...   Aug 2 2016, 06:06 PM
Reverend Troublemaker   Except now he stated the engine is out of the car....   Aug 3 2016, 12:28 PM
Jeffs9146   You could try to put it in 5th gear manually and t...   Aug 3 2016, 01:15 PM
mitche   You could try to put it in 5th gear manually and ...   Aug 6 2016, 07:28 AM
stugray   I can with a big hammer turn the flywheel so I ca...   Aug 6 2016, 11:01 AM
mitche   I can with a big hammer turn the flywheel so I c...   Aug 6 2016, 11:16 AM
mitche   [quote name='stugray' post='2381346' date='Aug 6 ...   Aug 6 2016, 12:30 PM
stugray   Well the bottom two bolts are studs (correct wor...   Aug 6 2016, 01:19 PM
76-914   then absolutely :beer2:   Aug 6 2016, 07:40 AM
cuddyk   Congrats! At this point you should be able to ...   Aug 6 2016, 12:46 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:38 PM
