> Relay board, Doesn't look right
Coondog
post Jun 6 2016, 11:17 AM
Still trying to figure out barely running 75 1.8 L jet blues
Looked at relay board and found missing rear window defogger fuse which is no big deal but also saw missing power supply relay fuse ???? Unknown what this is for. Then unknown yellow wire.
Dave_Darling
post Aug 10 2016, 02:50 PM
914 Idiot
Try unplugging the black/purple wire that goes from the coil to the tach. It probably won't help, but if it does then that is a big hint about what is causing problems. Remember that grounding out that black/purple wire will cut off the spark completely, so an intermittent ground or even just wonky resistance could cause strange problems.
The bouncing tach may be just from the tach itself, or it may be a lousy signal from the points. If the latter, that can cause fuel injection problems because L-jet uses the ignition signal to tell the injectors when to open.
--DD
Coondog   Relay board   Jun 6 2016, 11:17 AM
timothy_nd28   Yellow wire goes to the starter   Jun 6 2016, 11:21 AM
Coondog   Thanks, tach bounces when I get can get it to rev ...   Jun 6 2016, 11:37 AM
timothy_nd28   most of them do, the dielectric in the 40 year old...   Jun 6 2016, 11:53 AM
Coondog   What is the power relay fuse used for ??   Jun 6 2016, 01:09 PM
timothy_nd28   not used in your application. Ljet systems have t...   Jun 6 2016, 03:12 PM
Coondog   Thanks again   Jun 6 2016, 04:59 PM
Jason74914   Timothy, I know you are the FI guru, but my 18.L L...   Jun 6 2016, 07:41 PM
ClayPerrine   Timothy, I know you are the FI guru, but my 18.L ...   Jun 6 2016, 08:05 PM
timothy_nd28   It's good to question, let me show you the pat...   Jun 6 2016, 09:17 PM
Jason74914   Huh, very interesting! Sure makes diagnosis m...   Jun 6 2016, 09:28 PM
timothy_nd28   Electrically, the two rear ports are the same. Lo...   Jun 6 2016, 09:33 PM
Jason74914   I may have answered my own question. Looks like o...   Jun 6 2016, 09:34 PM
Jason74914   I may have answered my own question. Looks like ...   Jun 6 2016, 09:35 PM
timothy_nd28   Coondog: I would concentrate on the ignition side...   Jun 6 2016, 10:14 PM
malcolm2   Consider installing a [b]electronic ignition modu...   Aug 10 2016, 08:42 AM
Jason74914   Timothy, Car sat for a few years. After draining ...   Jun 7 2016, 05:35 PM
Dave_Darling   Try unplugging the black/purple wire that goes fro...   Aug 10 2016, 02:50 PM
oakdalecurtis   Not sure if you fixed your electrical issues yet, ...   Aug 10 2016, 04:45 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th February 2025 - 11:20 PM
