> Relay board, Doesn't look right
Coondog
post Jun 6 2016, 11:17 AM
Still trying to figure out barely running 75 1.8 L jet blues
Looked at relay board and found missing rear window defogger fuse which is no big deal but also saw missing power supply relay fuse ???? Unknown what this is for. Then unknown yellow wire.
oakdalecurtis
post Aug 10 2016, 04:45 PM
Oakdalecurtis
Not sure if you fixed your electrical issues yet, but even if you did, try this. Remove your relay board and look at the bottom. The boards were sealed with a tar like compound that seems to melt and decay with heat and age, especially below the voltage regulator. If it is degraded, the connectors beneath it will push down when the VR is inserted and result in poor or no contact. Good luck!
Coondog   Relay board   Jun 6 2016, 11:17 AM
timothy_nd28   Yellow wire goes to the starter   Jun 6 2016, 11:21 AM
Coondog   Thanks, tach bounces when I get can get it to rev ...   Jun 6 2016, 11:37 AM
timothy_nd28   most of them do, the dielectric in the 40 year old...   Jun 6 2016, 11:53 AM
Coondog   What is the power relay fuse used for ??   Jun 6 2016, 01:09 PM
timothy_nd28   not used in your application. Ljet systems have t...   Jun 6 2016, 03:12 PM
Coondog   Thanks again   Jun 6 2016, 04:59 PM
Jason74914   Timothy, I know you are the FI guru, but my 18.L L...   Jun 6 2016, 07:41 PM
ClayPerrine   Timothy, I know you are the FI guru, but my 18.L ...   Jun 6 2016, 08:05 PM
timothy_nd28   It's good to question, let me show you the pat...   Jun 6 2016, 09:17 PM
Jason74914   Huh, very interesting! Sure makes diagnosis m...   Jun 6 2016, 09:28 PM
timothy_nd28   Electrically, the two rear ports are the same. Lo...   Jun 6 2016, 09:33 PM
Jason74914   I may have answered my own question. Looks like o...   Jun 6 2016, 09:34 PM
Jason74914   I may have answered my own question. Looks like ...   Jun 6 2016, 09:35 PM
timothy_nd28   Coondog: I would concentrate on the ignition side...   Jun 6 2016, 10:14 PM
malcolm2   Consider installing a [b]electronic ignition modu...   Aug 10 2016, 08:42 AM
Jason74914   Timothy, Car sat for a few years. After draining ...   Jun 7 2016, 05:35 PM
Dave_Darling   Try unplugging the black/purple wire that goes fro...   Aug 10 2016, 02:50 PM
oakdalecurtis   Not sure if you fixed your electrical issues yet, ...   Aug 10 2016, 04:45 PM
- Lo-Fi Version Time is now: 7th February 2025 - 10:37 PM
