1970 914/6 Harness Horror, Main Wiring Harness Connection |
Howie149 |
Aug 10 2016, 08:42 PM
Newbie Group: Members Posts: 4 Joined: 10-August 16 From: Emerald Hills, CA Member No.: 20,286 Region Association: None |
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires. Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul. Attached thumbnail(s) |
cary |
Aug 10 2016, 09:06 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Your fired ...
You need to give the car to me .... LOL All kidding aside. No big deal. If you look closely at the black connector it should have little numbers. The schematic will have matching numbers. Just plug them back in the correct hole. I'm stripping down another 964 at work. While removing the 40# harness. One of the 6 pin versions behind the gauges came apart. I got lucky. It didn't explode like yours. |
Howie149 |
Aug 10 2016, 09:39 PM
Your fired ... You need to give the car to me .... LOL All kidding aside. No big deal. If you look closely at the black connector it should have little numbers. The schematic will have matching numbers. Just plug them back in the correct hole. I'm stripping down another 964 at work. While removing the 40# harness. One of the 6 pin versions behind the gauges came apart. I got lucky. It didn't explode like yours. Yeah I saw the numbers. I wish it was that easy. I don't have a schematic for that part of the harness. I have the shop manuals for the 914 but not going back to 1970. The schematics are for other relay brackets and different main harnesses. Everything else is either too small to read, not in color or clearly wrong. |
porschetub |
Aug 10 2016, 10:45 PM
Advanced Member Group: Members Posts: 4,750 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='Howie149' post='2383480' date='Aug 11 2016, 03:39 PM']
[quote name='cary' post='2383467' date='Aug 10 2016, 08:06 PM'] Your fired ... You need to give the car to me .... LOL All kidding aside. No big deal. If you look closely at the black connector it should have little numbers. The schematic will have matching numbers. Just plug them back in the correct hole. I'm stripping down another 964 at work. While removing the 40# harness. One of the 6 pin versions behind the gauges came apart. I got lucky. It didn't explode like yours. [/quote] Yeah I saw the numbers. I wish it was that easy. I don't have a schematic for that part of the harness. I have the shop manuals for the 914 but not going back to 1970. The schematics are for other relay brackets and different main harnesses. Everything else is either too small to read, not in color or clearly wrong. I have a schematic but I just looked and its for a 4 to 6cyl conversion ,try a google search 914/6 relay pins or similar,think I saw one a while back. Please move the Ashlock tach adaptor behind the dash where it belongs,these units aren't waterproof.it will fizz in this wet area. I will go back thru my notes and see what I can find on my old laptop...if it still works (IMG:style_emoticons/default/confused24.gif) Will get back soon hopefully. EDIT,found this from this site AA conversion book; Hope it is some use. |
Lo-Fi Version | Time is now: 22nd December 2024 - 11:53 AM |
