> 1970 914/6 Harness Horror, Main Wiring Harness Connection
Howie149
post Aug 10 2016, 08:42 PM
I have a 1970 914/6. When I pulled the motor out, the 14 pin Main Harness that sits on the Relay Board in the engine compartment came apart. Thus I have no idea which wire goes where. I have 6 wires. (2 are grey and black and go to the transmission back-up switch/sender. 1 Green and brown and 1 Green and black go to the oil pressure and oil level senders. 1 Black and red goes to the coil and I'm not sure about the black and blue/purple.) I have attached a picture of the harness below.
I would enjoy any guidance on where to plug these wires.
Car won't start and it keeps blowing fuses which I assume is either a problem with these wires or the ignition system/distributor needs an overhaul.
Peashooter
post Aug 11 2016, 05:42 AM
QUOTE(Howie149 @ Aug 10 2016, 10:42 PM) *
That is not a factory harness. Wire colors are totally different. Stock engine?
porschetub
post Aug 11 2016, 01:12 PM
QUOTE(Peashooter @ Aug 11 2016, 11:42 PM) *
Good spotting,no wire tracer colours,me thinks some time will be needed with a multimeter,expect the harness has been remade @ some stage ?,
The other metal box plugged in to the relay board is a signal convertor for the tach right ? so as mentioned why the tach convertor.
Howie149   1970 914/6 Harness Horror   Aug 10 2016, 08:42 PM
cary   Your fired ... You need to give the car to me .......   Aug 10 2016, 09:06 PM
Howie149   Your fired ... You need to give the car to me ......   Aug 10 2016, 09:39 PM
porschetub   [quote name='cary' post='2383467...   Aug 10 2016, 10:45 PM
cary   My manuals are at my shop. I won't be out ther...   Aug 10 2016, 09:41 PM
Peashooter   I have a 1970 914/6. When I pulled the motor out...   Aug 11 2016, 05:42 AM
porschetub   I have a 1970 914/6. When I pulled the motor ou...   Aug 11 2016, 01:12 PM
rgalla9146   I took a picture of the multi-pin connectors with ...   Aug 11 2016, 08:05 AM
JmuRiz   Why do you have a tach adapter ? I was thinkin...   Aug 11 2016, 08:24 AM
rgalla9146   Most likely a real 6, the oil line to the tank has...   Aug 11 2016, 10:39 AM
Dion   Why do you have a tach adapter ? I was thinki...   Aug 11 2016, 10:44 AM
Dave_Darling   If the wiring follows the same convention as the f...   Aug 11 2016, 12:22 PM
ClayPerrine   If the wiring follows the same convention as the ...   Aug 11 2016, 08:56 PM
Howie149   Its a numbers matching car but the wiring harness ...   Aug 11 2016, 07:57 PM
Perry Kiehl Clone   Looks like it could be one of my harnesses, or may...   Aug 11 2016, 08:16 PM
porschetub   Looks like it could be one of my harnesses, or ma...   Aug 11 2016, 10:24 PM
Howie149   Looks like it could be one of my harnesses, or ma...   Aug 12 2016, 12:14 AM
sixnotfour   :beer1:   Aug 11 2016, 09:25 PM
SixerJ   Positive you have a six board, two vertical plugs ...   Aug 12 2016, 12:43 AM
- Lo-Fi Version Time is now: 22nd December 2024 - 11:23 AM
