Engine Upgrade |
Engine Upgrade |
cal914 |
Aug 15 2016, 02:39 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I'm having my stock 2.0 6 engine upgraded to a 2.2S spec what type of power and performance will this give me and will there be a noticeable differences when I put the pedal down
Thanks B |
cal914 |
Aug 16 2016, 03:31 PM
I know there will be a big difference in s 4 cyl 1.7 and a 2.2 6 cyl I was asking what type of power a 2.2 gives you as I only drive a 1.7 at the moment
porschetub |
Aug 17 2016, 01:29 AM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I know there will be a big difference in s 4 cyl 1.7 and a 2.2 6 cyl I was asking what type of power a 2.2 gives you as I only drive a 1.7 at the moment Yes the S in a handful to keep on the boil so to speak,good friend had one in the early days it was major fun on the open road twisties but a dog in town. My motor is more or less stock 71 2.2t ,I haven't run my car as yet but if I was to update I would go with bored stock cylinders to 86mm and JE custom 9:1 pistons,biral cylinders are an option (preference), mild DC cams and a quality stock rebuild on heads. A well built -6 can easily double the HP of the 1.7 -4. This combination will yield a displacement of 2.3L and have a handy increase in power which will be fun to drive in ALL driving situations,at the end of the day it about how good the work is done to give you max bang for buck....it isn't cheap. Make sure you pick a good engine builder from the very start. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:30 PM |
