Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Again, I've been asked to make correct length heater cables. Apparently the ones on the market are a little too short. These have to be exactly the correct length otherwise they don't reach, and if they are too long the bind up in the flapper arm assembly and will not allow full travel of the flapper, making your heat on not fully on when selected.
These will be nylon coated cables pre-bent for the install at the lever. I've also included 2 free heater cable nipples to seal up the tubes while you are there. So, who's interested? These will be ready in about a week. And who can resist free nipples? Making the 70-74, and the 75-75 version Attached thumbnail(s) ![]() Attached image(s) ![]() |
80cap |
Member ![]() ![]() Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None ![]() |
I don't know how I missed this thread! I just bought a 70 thru 74 cable from Stoddard's.
I was told it is longer than my 76 cable but you can make it work by twisting the wire at the control handle. Is this true? Thanks Brian |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:41 PM |
