Spankins6 |
Newbie ![]() Group: Members Posts: 4 Joined: 5-August 16 From: Lancaster, Pa Member No.: 20,265 Region Association: MidAtlantic Region ![]() |
Hey all, I am new, so sorry if I mess up the flow.
I have tried searching and I can't find issues that other have had that are like mine. So I bought a 914 off ebay last week, I got a great deal. The only major issue is that when I start from a stop in first gear, it feels like I am running over a pot hole or a large stick under my rear driver side wheel. It only happens in first, and I can't recreate it in any other gears. I don't feel any binding up, so I dont think its the CV. And the shifter stays in place, so I dont think its the trans mount. Has anyone ran into this issue before? If so, what do you think it could be? Thanks! ![]() |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Engine mounts on front support bar sheared?
MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
Spankins6 |
Engine mounts on front support bar sheared? Absolutely. IMO, that thump is yer engine lifting up and dropping back down into the engine bar. Your mount is likely split right in half, at least on one side. Thanks again! Need to order the parts, where do you guys like ordering from? |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Engine mounts on front support bar sheared? Absolutely. IMO, that thump is yer engine lifting up and dropping back down into the engine bar. Your mount is likely split right in half, at least on one side. Thanks again! Need to order the parts, where do you guys like ordering from? Get under the car and look before you order anything. A bad engine mount can be seen. Loose shocks can be seen. Missing bushings can be seen. Don't just throw money at it. Take an afternoon, get under the car and look. (and yes - I know damn well the pot calling the kettle black) Zach |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Engine mounts on front support bar sheared? Absolutely. IMO, that thump is yer engine lifting up and dropping back down into the engine bar. Your mount is likely split right in half, at least on one side. Thanks again! Need to order the parts, where do you guys like ordering from? Get under the car and look before you order anything. A bad engine mount can be seen. Loose shocks can be seen. Missing bushings can be seen. Don't just throw money at it. Take an afternoon, get under the car and look. (and yes - I know damn well the pot calling the kettle black) Zach Yes! I should have mentioned in my post above, you dont need any fancy camera. Just climb under the car and have a look. The rubber engine mounts are under the fan shroud on top on the engine mount bar. (That is for a later - side shift) For a tail shift, there will be solid brackets in that location and the soft mounts are outboard where the bar connects to the body. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:43 PM |
