Fuel leak from fuel line going through tunnel |
22truckie |
Aug 19 2016, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 23-June 16 From: Lake Stevens WA Member No.: 20,138 Region Association: None |
Ok. Here is my problem. The main fuel supply plastic line that comes from the fuel tank under the car and through the tunnel is slowly leaking/ more like seeping fuel from where it comes out of the tunnel through a small rubber donut plug ( it is next to a metal funnel piece that I believe the clutch hose goes through (?). Anyway there is another fuel hose right next to it ( the return line ?). That one is fine. Both have a substantially sharp bend in them as they come out of the rubber grommet at the very bottom of the fire wall under the car. The first Jose I describe ( the one right next to the metal funnel is leaking right at the sharp bend. I am assuming the leak is at the very sharp bend in the line as it exits the tunnel. My question is this: Can I pull on the plastic line as it comes out of the tunnel to expose the leak at the bend and splice in high pressure rubber hose with clamps to fix the leak? I assume the other end of this line is in the fuel tank area. Is there enough slack in the system on the other side to pull some through to accomplish this? Thoughts? Ideas??? Thanks guys!!!!
JawjaPorsche |
Aug 19 2016, 02:41 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Just replace them with stainless lines from Tangerine Racing. Don't cut corners with your teener!
BeatNavy |
Aug 19 2016, 04:04 AM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Just replace them with stainless lines from Tangerine Racing. Don't cut corners with your teener! (IMG:style_emoticons/default/agree.gif) Don't even attempt to "repair" or splice the plastic line. Buy these: http://www.tangerineracing.com/stainlessfuellines.htm And do this: http://www.914world.com/bbs2/index.php?showtopic=168383 It can be done with engine in the car. It's not that hard. There's a instructional video floating around about how to do it that I can never get my hands on when I need it...but again, it's not that hard, and there are other threads here on the site with people's experiences doing this. Good luck. |
mepstein |
Aug 19 2016, 06:00 AM
914-6 GT in waiting Group: Members Posts: 19,512 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just replace them with stainless lines from Tangerine Racing. Don't cut corners with your teener! (IMG:style_emoticons/default/agree.gif) Don't even attempt to "repair" or splice the plastic line. Buy these: http://www.tangerineracing.com/stainlessfuellines.htm And do this: http://www.914world.com/bbs2/index.php?showtopic=168383 It can be done with engine in the car. It's not that hard. There's a instructional video floating around about how to do it that I can never get my hands on when I need it...but again, it's not that hard, and there are other threads here on the site with people's experiences doing this. Good luck. (IMG:style_emoticons/default/agree.gif) don't cheap out. For $150-200 do it right and safe. Give Chris a call, he will put together the correct package for your car and you will be good for another 45 years. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:57 PM |
