Fuel leak from fuel line going through tunnel |
22truckie |
Aug 19 2016, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 23-June 16 From: Lake Stevens WA Member No.: 20,138 Region Association: None |
Ok. Here is my problem. The main fuel supply plastic line that comes from the fuel tank under the car and through the tunnel is slowly leaking/ more like seeping fuel from where it comes out of the tunnel through a small rubber donut plug ( it is next to a metal funnel piece that I believe the clutch hose goes through (?). Anyway there is another fuel hose right next to it ( the return line ?). That one is fine. Both have a substantially sharp bend in them as they come out of the rubber grommet at the very bottom of the fire wall under the car. The first Jose I describe ( the one right next to the metal funnel is leaking right at the sharp bend. I am assuming the leak is at the very sharp bend in the line as it exits the tunnel. My question is this: Can I pull on the plastic line as it comes out of the tunnel to expose the leak at the bend and splice in high pressure rubber hose with clamps to fix the leak? I assume the other end of this line is in the fuel tank area. Is there enough slack in the system on the other side to pull some through to accomplish this? Thoughts? Ideas??? Thanks guys!!!!
RAX914 |
Aug 19 2016, 08:20 AM
Member Group: Members Posts: 100 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None |
You should also inspect/replace the lines in the engine bay as well. There are a couple of plastic lines there also.
mepstein |
Aug 19 2016, 08:35 AM
914-6 GT in waiting Group: Members Posts: 19,333 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You should also inspect/replace the lines in the engine bay as well. There are a couple of plastic lines there also. Yes, I had small leaks on my car, weaping lines, until ALL the lines were replaced and new seals on the injectors. A fi car shouldn't smell like gas. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:35 AM |
