Fuel leak from fuel line going through tunnel |
22truckie |
Aug 19 2016, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 23-June 16 From: Lake Stevens WA Member No.: 20,138 Region Association: None |
Ok. Here is my problem. The main fuel supply plastic line that comes from the fuel tank under the car and through the tunnel is slowly leaking/ more like seeping fuel from where it comes out of the tunnel through a small rubber donut plug ( it is next to a metal funnel piece that I believe the clutch hose goes through (?). Anyway there is another fuel hose right next to it ( the return line ?). That one is fine. Both have a substantially sharp bend in them as they come out of the rubber grommet at the very bottom of the fire wall under the car. The first Jose I describe ( the one right next to the metal funnel is leaking right at the sharp bend. I am assuming the leak is at the very sharp bend in the line as it exits the tunnel. My question is this: Can I pull on the plastic line as it comes out of the tunnel to expose the leak at the bend and splice in high pressure rubber hose with clamps to fix the leak? I assume the other end of this line is in the fuel tank area. Is there enough slack in the system on the other side to pull some through to accomplish this? Thoughts? Ideas??? Thanks guys!!!!
napasteve |
Aug 19 2016, 03:19 PM
914 driving winemaker Group: Members Posts: 508 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Where is your fuel pump? Up front or back under the engine shelf?
Either way, I also recommend Tangerine SS lines. I'm not a mechanic and even I could replace the lines (fyi you can do this with the engine in place). I also installed a new fuel pump because the original stopped working (perhaps because it sat dry for 6 weeks?). Once the new lines are in, no more gas smells or anxiety about the car burning up thing. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:55 PM |
