rruffer |
Newbie ![]() Group: Members Posts: 8 Joined: 2-June 16 From: Bernardsville, NJ Member No.: 20,063 Region Association: North East States ![]() |
I installed a Momo 8002 hub with the horn/directional turn off ring from my OEM steering wheel. Either due to the ring fitment or cast of the hub, turning the wheel creates a rubbing against the column controls. So sometimes the horn would go off or my high beams would flash. I've sorted some of this out with electrical tape or bending contact plates to avoid the inadvertent contact. I think a better solution, though, would be to space the hub out just a little.
My question is whether the hub actually rests against the C'clip on the steering shaft, so I could insert a washer or two to space out the hub, or is the shaft and hub a tapered fit? Any thoughts or suggestions? Thank you, as always, to the amazing wealth of knowledge on the Board!! |
ThunderbirdDrive |
Newbie ![]() Group: Members Posts: 31 Joined: 3-March 16 From: Toronto Canada Member No.: 19,724 Region Association: Canada ![]() |
I'm experiencing the very same problem since I installed my Momo hub.
I just added a second c-clip and that pushed the hub out slightly and stopped all rubbing when I turn. Unfortunately the horn still occasionally goes off when I turn. It's got me scratching my head. I installed a new horn contact ring as the old one looked a bit gouged out. Horn still occasionally goes off on its own. I do have a bit of free play in the steering colum, so I just ordered the 928 steering bushing quick fix sleeve. Let's see if that makes a difference when it arrives. How's the free play in your steering column, I'm wondering if this is the route cause? |
rruffer |
I haven't noticed any free play, but there may be some. I'll need to check. I'll try the additional c clip. I fixed the horn issue by adding some electrical tape along over the column contacts. I just left the "springy" part of the contact exposed. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:42 PM |
