914-6 Engine Height at the front of the motor?, Need help with a measurement |
jkb944t |
Aug 20 2016, 06:40 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I need to know what the correct height of a 914-6 motor is at the front of the motor as shown in the picture. I think my motor is too high at the front.
Jeff B |
wndsnd |
Aug 20 2016, 08:37 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Well my car is a conversion, so my answer is not what you are looking for, but it interested me after seeing your post so I measured it.
I have a modified custom mount and we actually played with it in a couple of variations. First I was concerned about shift rod clearance. Secondly I was concerned with sheet metal fitment. We finally settled on matching the sheet metal to the engine bay gasketing and shelf, which gave me plenty of clearance on the shift rod. After all was said and done, measuring like you did in your photo, we are basically dead on together... My measurement matches yours as shown. FWIW... (IMG:style_emoticons/default/beerchug.gif) |
porschetub |
Aug 20 2016, 09:24 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Well my car is a conversion, so my answer is not what you are looking for, but it interested me after seeing your post so I measured it. I have a modified custom mount and we actually played with it in a couple of variations. First I was concerned about shift rod clearance. Secondly I was concerned with sheet metal fitment. We finally settled on matching the sheet metal to the engine bay gasketing and shelf, which gave me plenty of clearance on the shift rod. After all was said and done, measuring like you did in your photo, we are basically dead on together... My measurement matches yours as shown. FWIW... (IMG:style_emoticons/default/beerchug.gif) Thanks for reply John I will check mine when the rain stops and hopefully help the OP also,think my height is correct but PO has cocked up my engine carrier mount and the engine is too far rearwards. Measurements @ the gearbox mounts shows around 15mm out ,ticks me off as he said the mount was a exact copy of an original -6 mount he had the use of for a pattern. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:49 PM |
