Need electrical help- no spark., HHHHHHHELP! |
tornik550 |
Aug 20 2016, 01:56 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I built a /6 2.7 this past winter. I originally ran the engine on a test stand so I could work out all of the bugs. The engine ran great. I had a fairly simple electrical setup and I did not hook up my alternator. Since everything was workin well, I installed the engine in my 914. Once hooked up, I started the car and it ran great for a few minutes than I had to turn it off for unrelated reasons. A week later, I tried to start it up again and everything worked great. Then a couple of days ago, I tried to start the car and after the engine would crank awhile, you could occasionally hear a cylinder fire but the engine never started. Since then, I have not been able to get the engine to start or even any signs of spark.
To check for spark, I hooked up a plug wire to an old spark plug, layer it on the engine, cranked it and looked for spark. I have a msd blaster 2 coil, pertronix ignition, new distributor cap and rotor, new clewett wires. Here is what I have tried- none has worked- I tried the above test with each of the listed changes. -I have tried three different pertronix ignitors (two brand new) -tried three difference could- Bosch blue, msd blaster 2, accel super stock (none of the three are new- I thought they work ok however?) -I tried a new set of points (I did get one spark 1 time) -I have an msd 6al- no luck -battery has 12.8v I even tried rewiring everything as though it was on the test stand. Nothing was hooked up to the car- everything was directly to a separate battery -12v to starter -switched 12v to starter -pertronix + wire to + post on coil, - wire to - post -switched 12v to +post on coil -ground to -coil post That is all that was hooked up and still no spark!!! Spark plugs are brand new also. I just don't get it- I have mega simplified the system- everything worked fine and now nothing. I don't even car if the engine doesn't fire- as long as I am getting a spark, I can work from there. |
tornik550 |
Aug 21 2016, 05:47 PM
I hadn't noticed this however I have a small crack in my distributor cap. It is quite small. Could this lead to my weird issues? I have gotten to the point where I can occasionally get a spark using points. It is only occasional.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th June 2024 - 11:21 PM |
