MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
Greetings from Munich gentlemen!
As seen in the title, my car (1973 1.7 converted to 2 liter, D-Jettronic F.I.) idles at 1000 after starting and letting it sit. When I take it out in the road it quickly changes to 1400. It still idles at 1400 when stopped after the car is warm. 1) I think my AAR (auxiliary air regulator) valve isn't working at all. Disconnecting the vacuum hose, the idle shot up to about 3000 and covering it with my finger 100% it went back down to where it was before I had detached it from the AAR. So the AAR should have been OPEN as the car wasn't warm yet, but it seems to be closed 100%. Strangely, the idle only goes up after the car is out on the road / is warm...but not even yet near normal operating temperature. I'm thinking the AFR is leaning out under load and after the car is fully warmed up. (IMG:style_emoticons/default/idea.gif) I currently don't have AFR or CO values. I will have the CO measured cold and after warming up in a few days. Here's another issue and question fer y'all. While looking into the bay yesterday I noticed a substantial leak at one of the fuel injectors. I didn't mess with it much (checking the seating of the seal) but after I drove the car and it was warm, I looked again and it had stopped leaking. I thought it could have something to do with temp and fuel pressure (IMG:style_emoticons/default/confused24.gif) Starting up the car cold this morning however, I checked again, and there was still no leak. Does anyone have any idea what could cause an apparently intermittent leak like this? Perhaps just fudging with it gently got a seal to sit better, but I'm skeptical about that. Thanks for your feedback! (IMG:style_emoticons/default/beerchug.gif) By the way, I do know about this thread on Rennlist, which is a tremendous resource: http://members.rennlist.com/pbanders/djetparts.htm Mike in Munich |
MikeInMunich |
Update!
I got the AAR to work by letting it soak in WD40 for a day. Searching for a vacuum leak by spraying brake cleaner all over the place in the engine compartment, practically, the idle would drop from 1400 to under 1000 when I sprayed the "tip" of the fuel regulator, where there is an 11mm screw, which I couldn't easily get to turn in either direction (at all). I was curious, but pursued that attempt no further. Does this tell us anything? (IMG:style_emoticons/default/confused24.gif) Also, my fuel leak at the O ring of the injector is intermittent. Sometimes when I start the car up its leaking quite badly and more often than not, it's not leaking at all. Any ideas on why this could be the case? (IMG:style_emoticons/default/confused24.gif) Thanks guys! Really appreciate your help a LOT! All the best from sunny Munich, Mike (IMG:style_emoticons/default/smilie_flagge6.gif) |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Update! I got the AAR to work by letting it soak in WD40 for a day. Searching for a vacuum leak by spraying brake cleaner all over the place in the engine compartment, practically, the idle would drop from 1400 to under 1000 when I sprayed the "tip" of the fuel regulator, where there is an 11mm screw, which I couldn't easily get to turn in either direction (at all). I was curious, but pursued that attempt no further. Does this tell us anything? (IMG:style_emoticons/default/confused24.gif) Also, my fuel leak at the O ring of the injector is intermittent. Sometimes when I start the car up its leaking quite badly and more often than not, it's not leaking at all. Any ideas on why this could be the case? (IMG:style_emoticons/default/confused24.gif) Thanks guys! Really appreciate your help a LOT! All the best from sunny Munich, Mike (IMG:style_emoticons/default/smilie_flagge6.gif) If your injector o-ring is leaking, you need to replace ASAP. Otherwise, you will have a fire on your hands. The o-rings are cheap. Install is pretty easy (heck, I did it). Have you grabbed the numbers off your ECU and MPS? http://members.rennlist.com/pbanders/index.html Look for this section: D-Jetronic D-Jetronic Injection System Fundamentals D-Jetronic Parts Table, Setup, and Troubleshooting Manifold Pressure Sensor (MPS) Analysis and Tuning D-Jetronic Electronic Control Unit (ECU) Analysis D-Jetronic PCV (Positive Crankcase Ventilation) Valve Analysis D-Jetronic Idle Stability and Troubleshooting D-Jetronic Testers Fuel Pump Circuit Troubleshooting Flow Charts (Framed Visio flow charts) D-Jetronic vs. Carburetors - The Endless Debate |
Lo-Fi Version | Time is now: 20th June 2024 - 09:19 AM |
