malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I recently did some ALT work and had to remove the flapper box. When I put it back, I guess I had the cable too tight and the damn thing was left open slightly.
90+* outside and my foot was burning up. (IMG:style_emoticons/default/shades.gif) I pulled it off and checked it out. The thing really does not seal very well even with the pull cable totally off. And it seems to be impossible to re-work or improve. I shined a light in the HE end and the flap just does not touch the box on the end away from the hinge. Short of buying a new one, does anyone have a solution? |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I battled the same problem for a while.
I had two problems: 1. The cable on the passenger side was too short. I had to pull on the heat box lever to get the barrel nut attached. I bent up some copper to use as a template and added weld to the end of the cable connection to increase the length. From what I hear this is a common problem with the cables. 2. The heater boxes were shot. After sweating for two years, I figured it was worth $200 to pop on a new Dansk set. http://www.ebay.com/itm/Porsche-914-914-6-...cVY&vxp=mtr |
Lo-Fi Version | Time is now: 26th June 2024 - 02:50 AM |
